Bit hard to explain, but having a surging problem when travelling at a constant speed (only happens over 100km/hr)
Happens at various speeds over 100.... eg 110, 115, 120. Only does it if i hold the accelerator at a constant speed. as soon as i de-accelerate or speed up it goes away. It also does not surge at a constant speed up hill (so shows it is not a problem under load)
I have changed the plugs, oil, oil filter, fuel filter, reset the ecu, changed the timing belt, had a code check... but no luck. I have also tried going back to 3rd gear in case it was a top gear problem... still no results.
I think its just a conicidence, but this surging problem started around the time I did an oil change and replaced the fuel filter...... could the new filter be a problem...?
Any help or suggestions would be great. I've had enough of this problem :)
https://www.sau.com.au/forums/topic/362368-strange-surging-problem/
  • Replies 41
Forgot to mention that....
Already cleaned the throttle body, the AFM, and the air filter. I have a K & N Filter.... oiled
also replaced the foam seal around the snorkel (filter had lots of foam sitting on it from the old seal...
Running V-Power
hmmm, can't remember the revs it is sitting on at 110 (in 'D')
Edited by NYL83R
Probably waaaay off but I had a similar problem when I had my alarm installed.
Turns out the guy installing it hadn't clipped the the little plastic clippy thing into the positive terminal properly, it seemed in but it wasnt and i only had symptoms at 90klicks
Mine did this too on a recent long distance trip. I would wind her up, then go to overtake only to have this surging nonsense, and the speed only increasing marginally.
It was definitely pissing me off.
The last time I drove a car that did this, it turned out the cooling system was partially blocked = Not flowing enough coolant.
I will investigate!
When I changed the timing belt, I also replased the thermostat, flushed the system and replaced coolant
Only surges when doing a constant speed.... the car will accelerate fine with no loss of power
I'll check the terminals....I'll try anything at this stage :)
I do have an aftermarket BOV (blitz) but it had this surging problem before I put it on....
I only stuck it on for a bit of fun cause i was changing the plugs and had it sitting in the cupboard :)
The more i'm thinking about this, I am thinking it could be the fuel filter. Perhaps the new one I put on is a dud or not compatible... I saved the old one just in case, so I'll stick that on tomorrow and see what happens
  • 3 months later...
well.... digging back into this thread to have another go :)
I am still having the problem mentioned above. I've changed back to my old fuel filter thinking that was the problem. but no luck. I was suggested to try another AFM. I've already cleaned mine, but could be a dud? Anyone have a spare they would be willing to lend me? big ask, but i don't really want to buy a new AFM on a hunch.
Does it feel like the whole car is jerking slightly? Do you often hear the Attessa relay click in the engine bay? (located driver side strut tower).
Because thats what mine was doing. Turns out it was the 4WD system playing up. The 'accumulator' was buggered, it is a high pressurised cannister that holds Attessa pressure up to the system. There's a few threads about it on SAU, common to GTR's and GTS-4s also.
Just an idea...
Cheers
Paul.
I have had the same problem years ago when i was using a k&N air filter the oil distroys the afm and u never get it all out i went to a use a paper air filter and cleaned the afm was heaps better but still did not totaly fix it till i replaed the afm and now i only you paper air filters and no more problem
Just an idea...
Cheers
Paul.
I agree and think it has something to do with the atessa system. How did u diognose ur accumulator was the problem?
If you have a S2 you can switch to 2wd as per the instructions or if your'e keen drop the front driveshaft to eliminate the attessa. Are all your tyres the same type and roughly the same state of wear? ( I think this unlikely as your cause but its easy to eliminate). I can send you an afm. Only trouble is I am assured it is good but not using one now as I have a G4 Link computer. Have you eliminated the O2 sensor? I think the easy way to do that is to just unplug it and go for a drive.
If you want to try my afm I just want the postage at this point and worry about the rest later (AU$60 to buy, postage probably about $20 - can let you know if interested).
thanks for the help guys. hmm I don't hear any clicking paul, would it be a noticable clicking when the problem starts? Yes the whole car jerks slightly. It could be my imagination, but since having this problem the car seems to have slightly less power overall? i'll investigate further. Could very well be the k&n oiled filter i have, after hearing what people are saying. I've had the filter in for a couple of years though before it started having this problem
I'll try unplugging the 02 sensor if you think it might help bob, otherwise I will take you up on that offer please. can you pm me bank details. cheers
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
