I'll get the name of the workshop and get back to you :)
Isn't Northshore the only place in Sydney approved to comply M35s?
Anyway, when I looked at your car before I bought mine, I got the impression it had an Impul ECU, in which case you won't need a flash I wouldn't have thought.
So me, Scott, Tonto, Dale. I'll talk to my intermediary on Monday and see what kind of deal we can get, be good to get a couple more people and make it sound worthwhile.
Does everyone have the same 3" (80mm?) exhaust?
My name is actually Rich. Lol! I don't think it matters if you don't have the exhaust right now lets get the tuning done for an exhaust i/c and whatever else and then you can just drop the ecu straight in and be ready to go. Three inch is 75mm so I don't know why he is on about about 80mm or 90mm, who has that?!!! I am definitely in on this. So who wants what? I want:
Boost raise to 1.1bar
Throttle restriction removal
Speed limit renoval (not fussed on this but it seems standard)
Leaning off of the mixtures foir better economy
I doubt the exhaust size would make much difference to max power with the stock turbo, If I was them I would be asking if the intake has been upgraded, lol. Of course that mod hasnt been done over there as far as I know.
They wont be leaning the mixture from stock, as it does a very good job already. If you want to save fuel, you need very good throttle control because the throttle plate opens to 60% at what seems to be 10% throttle pedal input. If they can attach the throttle to my foot I would be very happy. What was he talking about with the throttle, was he suggesting a cable one?
Well hopefully i score a bonus and it does, given the rest of the impul parts on the car, but if not I would be very interested.
He did ask about intake too Scott, air filter and intercooler specifically. According to him, there is a huge difference in 70mm and 80mm exhaust in terms of his mapping.
I couldn't work out what he was on about with the manual throttle, whether he was talking about the throttle or one of those throttle controllers. I've mentioned that to my intermediary and she said she must have got the translation wrong then, she'll find out more information when I'm ready. The more she talked about it though the more I thought he was talking about a throttle controller, so you could turn it down when you didn't need it as a safety thing when you have no restriction.
To give you some idea of what mine is like now, my missus drove me to the other side of Melbourne last night. I got a headache because her throttle control was useless, on boost off boost the whole way. She said she was barely moving the throttle but the ecu was obviously telling the actual throttle to move too much and with the stock turbo that makes for an interesting drive.
Normally I would turn down the throttle sensitivity with the throttle controller but lately when I activate it the ecu occasionally goes into limp mode (must be seeing a difference in resistance between the two potentiometers in the pedal sensor) which kills all power and almost idles down the street. Obviously I don't want this happening when she is driving so I had to just put up with it. With the highflow in the throttle is less sensitive until boost kicks in so that is the main issue, with such a large throttle plate and high boost, it will either force the plate open or just force past it.
I have already driven the car with a 70mm cable throttle and it was great, other than the cams remaining retarded which meant the midrange was much less responsive. If I must go back down that path I will, I would just prefer to get the ecu remapped if it will clear this up. (I doubt it will help much though). Unfortunately it has been impossible to communicate all this to the Japanese tuners so far so I have no idea if they can help. I think I would prefer to just cut the ecu out, put in a PS2000 and go manual.
Maybe he's talking throttle controller then, with no restriction in the ECU maybe he's thinking we should have the option of adjusting the sensitivity. Except sounds like these don't work properly?
I'll put some more questions down and see what he says. I'll ask about standard map, no restriction too.
guy's as Ironpaw said.....stock tune!!!!! just tell them you have a stock exhaust.....throttle and speed limit are your only needs!!!!!....you can piggyback and tune from there!
The issues for most guys is the extra cost in getting a piggyback installed and tuned. I guess the good thing about the remap is that its a cheap way to get a semi accurate tune for your mods...though who knows how it will be like when u start adding mods after the remap
Edited by ironpaw
True, except more mods after the remap would usually require a piggyback anyway, i.e. turbo, injectors, etc. Always was on the cards.
The standard Gzone remap does not get rid of the throttle restriction.
It is an extra optional expense, so might as well dictated other stuff while they have the ECU.
Can't hurt to get the guesstimate tune a little closer while waiting/saving for a piggyback.
Well can't they just copy the stock ECU settings/tune then remove the restrictions?
For myself I don't need their guesstimate tuning...
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
