Is your 44k yen price inclusive of the throttle restriction removal and speed cut?
According to their listing on YAJ the list price is 44k. BIN @ 46k
http://www.importmon...RO%20SPEC%20ROM
Note this on their listing:
It starts coming out at setting, and the entire area an empty torque impression there is, setting, very much is popular. The map of the NM35 electronic control throttle short story low/row which only NISUMO understands until now, with) modification such as variable val tie & electromotive fan start timing (temperature analytical real accelerator work in furthermore high power higher rotary limits was actualized until now. (Note!! Successful bid charge + separate option cost)
I think Cam found out it was a 20k yen option to remove the throttle restriction...
If your contact can get the remapped ECU WITH the restrictions removed for 44k yen then I'm impressed...
Edited by ironpaw
That was for simply_mighty, who wanted the tune minus the throttle restriction and speed cut.
You're right, its 20,000 yen to remove those. I'd like to think we can get this reduced if we're getting a few, and I haven't had a chance to ask if they can just do throttle restriction and speed cut.
Dude you don't need emanage if your just changing the exhaust, you only need it if you want to install the suction pipe and increase injectors size. Even then you don't HAVE to get an emanage. Cam isn't running one and his car's got all the mods done cept for injectors...I think.
Well that solves that then. It is on my list anyway. I've never had anything this 'high tech', so I'm just kind of feeling my way and erring on the side of caution. Doesn't help when you read/hear/get told different things and you're trying to work out what the best move is! All very confusing sometimes... I have bought myself more time now anyway, so might do the G-Zone anyway.
Yep, suction pipe, turbo, FMIC, spacer, full turbo back exhaust... and stock ECU.
It won't pull as much power from the car as a dyno tune with piggyback will, but you certainly will not NEED to install the emanage if changing the exhaust.
Love it. Thanks Cam. Bad info had made me think it was necessary and I was going to lean out and break stuff.
Are you keen on the G-Zone then? Or you looking at Emanage? Both?
I think I might do it when the car gets back.
Do we have enough ECUs floating around to send 4-5 over to get done at the same time? He might drop the price if he just has to remove speed cut and throttle restriction from 4-5 ECUs? These are all things I'll bring up with him when my Japanese contact gets back online, apparently its a holiday over there at the moment but Mr Amino keeps working away at G-Zone.
Dust hasn't done his write up yet, what's the advantage of the Fcon over the Emanage? Don't they both work as piggybacks and didn't I see you post that neither controlled the eVCT?
lol, my decision had nothing to do with Dust and his brief description of the change.
the Fcon iS is a piggyback - takes the ECU's signal to the engine and manipulates it (like the eManage)
The Fcon V Pro is installed like a piggyback but can be used as a standalone unit - cuts off the ECU's signal to the engine and sends its own.
Controlling the "eVCT" is an unknown to me right now.
The iS can control NVCS (Nissan Variable Cam Timing) which was used in the RB25's but I am not 100% sure about controlling the timing in a VQ25det... yet.
Edited by iamhe77
I asked to G-ZONE over e-mail and he replay this email.
デンスロは、別途オプションですが、ノーマルデーターが沢山あるため、オプションにも対応できていません。
解析が必要なのです。G-ZONEのステージアのコンピューターが評価が高いですが、デンスロをいじった車はありません。
出だしが遅いステージアに関しては、吸排気系のバランスが取れてないか、(燃料、点火時期)だと思われます。
ステージアは、酷く燃料が中回転だけ、濃く後は、ノーマルでも薄い状況です。
stagea has too many ecu number (I think 12)so electric throttle is option but we can not change throttle map.
Many stagea have been installed on our remap ecu and are very happy but we have not been selling remapped throttle map ecu.
We think your stagea problem is fuel or timing map problem.
Stagea is very rich at middle rpm and after middle rpm is lean.
Also TEPS is able to change throttle map but have not been soling remapped throttle map ecu.(customer is happy)
I know ecu specialist and I spoke to him and he is able to make map for 98 octane fuel.
If you are not happy he will adjust map again.
Its free but you need pay postage.
He will change fuel , timing , also throttle map , remove limiter.
Price 60000yen all included.
Cheaper than G-ZONE.
Thanks Toshi, very helpful. I take it you are not going to buy the reader/writer yourself? I think at around $500 for a remap the reader will pay for itself very quickly as I think there is at least 10 people wanting this done.
Tools around $7000.
$500 for US nissan car.
Japanese car can not use it.
Also $500 one can not map trace and datalog.
M35 is I think around 12 type ecu and all different program.
So If I do my self I need map tracer and data logger.
ECU tuner said if this ecu will engine knock , too rich , too lean , I will remap again.(its free but need postage)
So I think this is best way now.
Sounds like this might work; Toshi, would you be able to arrange a run up on a dyno to observe how the remapped ECU behaves, and then provide feedback to the tuner regarding any issues if any arise as part of the process?
If so, I'd volunteer, if someone is prepared to loan/rent me an ECU? Otherwise, who's willing to go first?
You have an informeter don't you Daleo? I just want to know if they can fix... Actually dont bother. lol.
Sounds positive :)
Lom changes
Speed ​​limiter changes
Fuel Data Map Change
Valve timing control map change
Ignition map changes
Throttle control map change
Professional expertise Romuchuna injection
The acceleration torque from launch.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
    • 😜 hopefully we get this instead of a new R36 GTR due to recent financial problems at Nissan. Nismo to sell a complete kit with RB26 and driveline. All starts making sense (ok maybe not) once the Nissan Leaf's (Leaves?) with stuffed EV motors/batteries hit the market cheap
    • Hi guys , have had allot of time for SAU and has helped me out heaps in the past so I thought I would give it a go , I have my QM1 white NUR for sale 1 of 156 examples built by Nissan. Serious personal messages please if interested and details will be provided , asking 500k
