It is possible to see a significant performance increase from a remapped ECU as long as those that remap it are aware of your mods, have a heap of experience with the model of car and, finally, are damn good at what they do.
It will never be as accurate as an in-car tune, but going from 140awkw to 190awkw on a remap with supporting mods done would not be out of the realms of possibility.
G-Zone want to know specifics of your setup, as many as they can get without actually physically having the car. Details are pretty much limited to intake/exhaust though, i.e. what air filter, exhaust, diameter of exhaust, intercooler upgrades, etc, and they supply your reflashed ECU according to these specs.
They seem to know more about the cars than anyone else, and from my research seem to be good at what they do.
I'm still sitting on the fence at the moment, second guessing a bit, but from what they're asking sounds like I should get the exhaust and front mount done first (my next two things) before I go with the flash, and that way I can supply them the exact pipe diameter, which they seem to want.
I wonder if I can just do a log on the emanage and send it to them? The output fuelling map and timing maps may help them but its probably best I tell them the basics and adjust the rest here.
Not much room left, the wastegate is going to mount under the housing.
Yes, it's on my extremely long list of thing to do...
Re; boost control. Is that because you can build full boost lower in the rev range?
The boost controller has a Gain setting that allows you to bring the boost on earlier and faster plus a little more pressure. I am running 17psi and this gives a good launch even without stalling it up but I do know what you mean.
The Impul does not change the throttle response significantly (if at all) but it does improve the fueling, remove boost cut, speed limiter and increase rev limit.
As was mentioned, my best estimate is around 180kw but Spoolin's car had 215kw with basically the same mods so this could well be closer to the mark especially as I hit 100% duty cycle around 7000rpm.
The issue of improving the throttle response with a remap like the Nismo ECU is that when Jetwreck had his tune done on his car (270kw) the tuner had to decrease the response of the throttle as it was too hard to work with in creating a safe tune.
I don't know the answer but it is a complicated ECU.
Looking good Scott... :)
So... remap might be useless later on when used with a piggyback?
i dont think these pictures do much justice. see it in person, and you'll see how the clearance is. its going to be fun scott. thats all I can say!
nice work scott.....looking good!!!
Well I'm still up for the re-map. For the price we are going to get an ecu that is somewhat custom written for the mods we have so I think it's worthwhile over a generic Mines or Impul one. For Craig and Scott with heavily modded cars it is probably a different story but I'm never goin that far with my car and the only other mod I can think of doing is maybe a boost controller. I've pretty much convinced myself this is what I'm going to do unless someone sneds me an Impul or Mines or Nismo ecu for $100. Craig? Andy??? Anyone?
lol Thats what they all say.
if your thinking about mofifying one or two things.. just a heads up at the domino effect.
Nah I have been there many times and have learnt my lesson! This car's mds will end with the ecu and MAYBE a boost controller. I'm not rebuilding gearboxes etc. This car is never going to be stupid fast witout a LOT of money spent on it and if I wanted to do that I would start with a VQ35 and do what Scott has done.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
