Sounds positive :)
Lom changes
Speed ​​limiter changes
Fuel Data Map Change
Valve timing control map change
Ignition map changes
Throttle control map change
Professional expertise Romuchuna injection
The acceleration torque from launch.
In this instance does "Throttle control map change" equal what we want, or is it just modifying the shape of the curve like those plug in controllers from Pivot etc?
Edited by Commsman
But not user programmable to cover future mods, correct? So you'd get basic (standard?) fuel, ignition/cam etc maps and then still need a piggyback of some description for tuning beyond that?
I got a reply from the South Africans and their system is $531 delivered, and it does some piggyback functions as well, for those that don't want or need tuning to extreme levels.
The ECU flash appeals to me more but maybe not ideal for everyone. Who's going to volunteer to try it first?
Toshi/Guy's,
Just letting you know I was chatting to Ian and the Nismo ECU open's at 86% from idle......and half the reason the guy in this video
is awesome is because more than likely he has one! Edited by Jetwreck
I can has awesome also?:whistling:
no ones seen anymore awesome on IM in a LONG time.
i hope someone else can get a Nismo ECU so they also can wear the stripes proudly. One day ill install the 3rd stripe that isnt the same colour as my car.
  • 5 months later...
Nope. I was pretty close to going G-Zone, just decided to do a couple more mods first. Now I don't have to.
Worth it IMHO if you're not going for big numbers. Gets a tune then you're done. But not as if you can retune all the time.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
