Hey!!
Looked through the V-series section and couldnt find a direct answer to my question.
To sum it up: I need new brake Pads.
As a total noob to most mechanics of the car I am unsure of what pads i need for my car. The pads I have currently have around 30%-40% but squeak like hell and need new pads desperately.
Im budgeting around $300-$400 inc labour but I would like to source the pads my self and get the mechanic just to fit them.
I have a 2004 350gt 2nd anniversary coupe. Stock brakes no brembo's.
I may track my car pretty soon so I need pads that can take a beating, not squeak like hell and are good for daily use.
Thanks :D
https://www.sau.com.au/forums/topic/362418-brake-pads/
Hey!!
Thanks :D
Send GSL Rallysport a PM, or check the trader section for them, they do great deals for forum users.
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5784259
Agree give Greg from GSL Rally sport a call. I have same brakes as you, non brembo on a sedan, and A1RM pads from QFM are a great performance pad that can take track day use.
Be especially careful to do some cool down laps before parking as I warped my first set of rotors not doing that. Unfortunatey these brakes are right on the limit for track use and if doing more than 5 laps in a row would suggest easing off in the middle of the bracket to let them cool a bit.. Check out the earlier posts this year from 180wanabe who cooked a rotor on the track.
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5784388
I have Brembros so they prices are a bit more than non - brembos but after searching so many places i got prices direct from these two guys
Brembo F + R stoptech performace pads (Street use and Track, as good as project Mu without the rotor wear)
Place 1 (Grip-force brakes): $118 + 35 shipping
Place 2 (HRauto parts): $100 + 45 shipping
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5785327
I have gone through a few sets of pads
Completely destroyed some oem grade ones that were only 10k old in 1 track day, I drove home with almost no brakes at all the slots in my rotors will filled with pad warning lights galore on the dash "ABS, Brake warning light, slip, VDC"
2nd set was Ferodo DS2500 which I would rate as my favorite pad so far, work just as well as OEMs when cold but keep on keeping on when your at the track on your 5th hot lap. But like Grae35 said I allmost chewed through a rotor because of VDC constantly grabbing the front right brake whilst going around the sweepers - I stopped using VDC at the track after that, it was only holding me back anyway
3rd set is the QFM A1RM which iv done one track day on, I was a bit disappointed with them however my rotors got machined at the same time they went in which may be a reason why they didint feel as good. The front left rotor cracked that day anyway so iv replaced them with some RDA slotted as a band aid till I can sort something out like a set of Brembos. I'll see how they go on the fresh rotors next track day I go to however at the moment Im not sure when that will be as my cars having some issue with the ABS/VDC cutting out. I suspect a speed sensor is playing up as iv noticed the speedo drop down from 100 to 80 and then pick back up as iv been on the hwy
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5793704
I need new pads to and have NFI where to start, i have been looking on ebay found some Hawk pads for like $130 bucks for a G35 (same car) non brebo (same as my car). Then there is another set of Hawk but the touring style and they have a cable coming out of them in the pic and the street performance ones dont so confused any one clarify this ill post links below to em.
Touring
http://cgi.ebay.com.au/HAWK-BRAKE-PADS-PC-F-R-NISSAN-350Z-ALTIMA-INFINITI-G35-/290536304255?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a5502e7f
Street
http://cgi.ebay.com.au/HAWK-BRAKE-PADS-HPS-F-R-NISSAN-350Z-ALTIMA-INFINITI-G35-/230586591560?pt=Motors_Car_Truck_Parts_Accessories&hash=item35b0082948
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5793868
how do you find the DS2500 in term of dust?
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5794186
  • 2 months later...
Cost?
$70 for front pair + $50 shipping :thumbsup: OEM cost $280 for front and rear. They r gonna be my next pads cos OEM is too dusty.
http://www.ebay.com.au/itm/NISMO-03-05-INFINITI-G35-R-TUNE-FRONT-BRAKE-PAD-SET-V35-/200617826210?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eb5c117a2
Nismo tune R, part number 41060-rnz35
Edited by Nicko_2010
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5905823
  • 4 weeks later...
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
