Hey!!
Looked through the V-series section and couldnt find a direct answer to my question.
To sum it up: I need new brake Pads.
As a total noob to most mechanics of the car I am unsure of what pads i need for my car. The pads I have currently have around 30%-40% but squeak like hell and need new pads desperately.
Im budgeting around $300-$400 inc labour but I would like to source the pads my self and get the mechanic just to fit them.
I have a 2004 350gt 2nd anniversary coupe. Stock brakes no brembo's.
I may track my car pretty soon so I need pads that can take a beating, not squeak like hell and are good for daily use.
Thanks :D
https://www.sau.com.au/forums/topic/362418-brake-pads/
Hey!!
Thanks :D
Send GSL Rallysport a PM, or check the trader section for them, they do great deals for forum users.
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5784259
Agree give Greg from GSL Rally sport a call. I have same brakes as you, non brembo on a sedan, and A1RM pads from QFM are a great performance pad that can take track day use.
Be especially careful to do some cool down laps before parking as I warped my first set of rotors not doing that. Unfortunatey these brakes are right on the limit for track use and if doing more than 5 laps in a row would suggest easing off in the middle of the bracket to let them cool a bit.. Check out the earlier posts this year from 180wanabe who cooked a rotor on the track.
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5784388
I have Brembros so they prices are a bit more than non - brembos but after searching so many places i got prices direct from these two guys
Brembo F + R stoptech performace pads (Street use and Track, as good as project Mu without the rotor wear)
Place 1 (Grip-force brakes): $118 + 35 shipping
Place 2 (HRauto parts): $100 + 45 shipping
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5785327
I have gone through a few sets of pads
Completely destroyed some oem grade ones that were only 10k old in 1 track day, I drove home with almost no brakes at all the slots in my rotors will filled with pad warning lights galore on the dash "ABS, Brake warning light, slip, VDC"
2nd set was Ferodo DS2500 which I would rate as my favorite pad so far, work just as well as OEMs when cold but keep on keeping on when your at the track on your 5th hot lap. But like Grae35 said I allmost chewed through a rotor because of VDC constantly grabbing the front right brake whilst going around the sweepers - I stopped using VDC at the track after that, it was only holding me back anyway
3rd set is the QFM A1RM which iv done one track day on, I was a bit disappointed with them however my rotors got machined at the same time they went in which may be a reason why they didint feel as good. The front left rotor cracked that day anyway so iv replaced them with some RDA slotted as a band aid till I can sort something out like a set of Brembos. I'll see how they go on the fresh rotors next track day I go to however at the moment Im not sure when that will be as my cars having some issue with the ABS/VDC cutting out. I suspect a speed sensor is playing up as iv noticed the speedo drop down from 100 to 80 and then pick back up as iv been on the hwy
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5793704
I need new pads to and have NFI where to start, i have been looking on ebay found some Hawk pads for like $130 bucks for a G35 (same car) non brebo (same as my car). Then there is another set of Hawk but the touring style and they have a cable coming out of them in the pic and the street performance ones dont so confused any one clarify this ill post links below to em.
Touring
http://cgi.ebay.com.au/HAWK-BRAKE-PADS-PC-F-R-NISSAN-350Z-ALTIMA-INFINITI-G35-/290536304255?pt=Motors_Car_Truck_Parts_Accessories&hash=item43a5502e7f
Street
http://cgi.ebay.com.au/HAWK-BRAKE-PADS-HPS-F-R-NISSAN-350Z-ALTIMA-INFINITI-G35-/230586591560?pt=Motors_Car_Truck_Parts_Accessories&hash=item35b0082948
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5793868
how do you find the DS2500 in term of dust?
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5794186
  • 2 months later...
Cost?
$70 for front pair + $50 shipping :thumbsup: OEM cost $280 for front and rear. They r gonna be my next pads cos OEM is too dusty.
http://www.ebay.com.au/itm/NISMO-03-05-INFINITI-G35-R-TUNE-FRONT-BRAKE-PAD-SET-V35-/200617826210?pt=Motors_Car_Truck_Parts_Accessories&hash=item2eb5c117a2
Nismo tune R, part number 41060-rnz35
Edited by Nicko_2010
https://www.sau.com.au/forums/topic/362418-brake-pads/#findComment-5905823
  • 4 weeks later...
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
