I need new non brembo pads as well and sick of the dust.
i'm going to try the Akebono high performance street Ceramics for the front and Pro-ACT Ceramics for the rear
have to get them from Tirerack in the US http://www.tirerack.com/brakes/results.jsp?autoMake=Infiniti&autoModel=G35+Coupe+Leather&autoYear=2003&autoModClar=
Ezy03, I have the same problem - can't tell which. If you measure just the pad it's ~137mm, but if you include the tags on either side it's about 157mm. If you look at the shape of the pad, it's similar to the wider design (157mm), but there's a bronze plate it's secured with that is the shape of the smaller design (137mm). Arrgghh! pinch.gif
Let me know if you find out. I don't need 'em yet, but I will sometime...
i did realise in the pics they sent me that the 137 is clean from the top and the 157 has a ditch sort of thing in the middle (at the top) and two ditches at the bottom (left and right) and the 137 has a ditch in the middle at the bottom.
ill try to measure the length and then see which one has the ditches *if they are noticable)
137 - http://www.jnbk-brakes.com/images/watermark_images/5486a2aad5b9be0cd692915d5a16b0d5_watermark.jpg
157 - http://www.jnbk-brakes.com/images/watermark_images/25f8ef71ea1e3d854464dc7494aca1ab_watermark.jpg
I'm in need of new pads, and more than likely rotors for the rear at least. Has anyone dealt with these guys before?
http://www.ebay.com.au/itm/03-04-05-Nissan-350Z-G35-Brake-Rotors-CERAMIC-Pads-/390176649174?pt=Motors_Car_Truck_Parts_Accessories&hash=item5ad8572fd6#ht_972wt_905
Also, what's the advantage/disadvantage of cross-drilling and/or slots on the rotors? I presume cooling is one of them ....
http://www.ebay.com....d6#ht_972wt_905
havent dealt with them but im gonna guess your ass is gonna get kicked with shipping since there heavy, source locally I think would be cheaper.
That's what I was going to do next, enquire about shipping, as I didn't know how heavy they'd be... thanks for the tip!
Has anyone tried EBC Redstuff? I used to use them on my J30 Maxima (after coming to the realisation that the Greenstuff just didn't last with my spirited driving). Of course, I didn't have as wide a selection to choose from with that car so I'd be interested to know with the greater choices for the V35/36's what people's findings are.
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
