Hi all ,
decided to strip my car down.
all parts are still on the car , car is complete for now.
if people are interested in the bigger bits such as motor/box then ill have it stripped down quicker.
someone come chuck a deposit on the motor and box :)
cusco tension rod $80
d1 garage castor arms $80
project mu slotted rotors (front) $100
d1 garage rear camber arms $100
kts rear cradle bushes $30
racing gear n1 circuit coilovers $1,000
nismo strut brace with cusco brake stopper $160
skyline rear strut brace $100
surge tank with lines and fittings $250
bosch 044 external pump $140
cusco half cage minus crossbar $300
sparco sprint fixed back $250
nardi deep corn copy $120
boss kit $45
hks evc5 ebc $300
gtr wing $150
rb25det motor minus turbo setup $1700 (needs new oil)
trust td05 with custom intake / greddy dump pipe / custom front pipe $1100
z32 afm $140
nistune rb20 ecu $400 (Tuned for engine setup with td05)
gearbox $900 (has slight whine)
18x8 /9.5 +45 $700
30mm bolt on spacers $100
27mm bolt on spacers $100
custom 2.5" blast pipes $250
Greddy boost gauge $60 (no light)
hicas lock bar $40
front mount intercooler with piping $250
signal straight through exhaust $600
r33 complete shell , with rego & plates $POA
cusco 2-way Mechanical Diff in housing $ 700
All parts sold as is
No warranty
Come inspect before buying
Postage at buyers expense
No COD
Will hold items if 20% deposit is paid on bigger items
If there is anything ive missed i will update the thread as it comes to my attention
contact: 0419 848 600
Edited by DamageInc
https://www.sau.com.au/forums/topic/362420-wrecking-r33-drift-car/
Hi, I'm after the following parts:
1. Do you have any front bar indicators? If so, what do they look like and how much?
2. I'm after the front inner guard lining thing that covers up the section from the front inner guard to the front bar. If how much?
3. Am after both your set of 27/30mm spacers, I'll give you $150 both. Is this ok?
How much to post to 3012 POST CODE in VIC?
1. keeping them with the front bar, which is staying with the shell
2. lost them years ago, ha
3. already got a buyer for the 30mm's mate
castor arms and tensionrods are the same thing though?
can you up load a pic of both sets so i can choose lol
Edited by tm_r33
you sure yournot thinking of sway bar.
do a google image search on 'r33 tension rod' and on 'r33 castor arm'
they the same thing bro
http://www.google.com.au/search?q=r33+cusco+tension+rod&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&hl=en&tab=wi&biw=1920&bih=1077
cusco tension rod $80 SOLD
d1 garage castor arms $80 SOLD
project mu slotted rotors (front) $100 SOLD PENDING PICK UP
d1 garage rear camber arms $100 SOLD PENDING PICK UP
racing gear n1 circuit coilovers $1,000 SOLD PENDING PICK UP
skyline rear strut brace $100 SOLD PENDING PICK UP
surge tank with lines and fittings $250 SOLD PENDING PICK UP
bosch 044 external pump $140 SOLD PENDING PICK UP
gtr wing $150 SOLD PENDING PICK UP
z32 afm $140 SOLD
hicas lock bar $40 SOLD PENDING PICK UP
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 馃槢
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
