Hi all ,
decided to strip my car down.
all parts are still on the car , car is complete for now.
if people are interested in the bigger bits such as motor/box then ill have it stripped down quicker.
someone come chuck a deposit on the motor and box :)
cusco tension rod $80
d1 garage castor arms $80
project mu slotted rotors (front) $100
d1 garage rear camber arms $100
kts rear cradle bushes $30
racing gear n1 circuit coilovers $1,000
nismo strut brace with cusco brake stopper $160
skyline rear strut brace $100
surge tank with lines and fittings $250
bosch 044 external pump $140
cusco half cage minus crossbar $300
sparco sprint fixed back $250
nardi deep corn copy $120
boss kit $45
hks evc5 ebc $300
gtr wing $150
rb25det motor minus turbo setup $1700 (needs new oil)
trust td05 with custom intake / greddy dump pipe / custom front pipe $1100
z32 afm $140
nistune rb20 ecu $400 (Tuned for engine setup with td05)
gearbox $900 (has slight whine)
18x8 /9.5 +45 $700
30mm bolt on spacers $100
27mm bolt on spacers $100
custom 2.5" blast pipes $250
Greddy boost gauge $60 (no light)
hicas lock bar $40
front mount intercooler with piping $250
signal straight through exhaust $600
r33 complete shell , with rego & plates $POA
cusco 2-way Mechanical Diff in housing $ 700
All parts sold as is
No warranty
Come inspect before buying
Postage at buyers expense
No COD
Will hold items if 20% deposit is paid on bigger items
If there is anything ive missed i will update the thread as it comes to my attention
contact: 0419 848 600
Edited by DamageInc
https://www.sau.com.au/forums/topic/362420-wrecking-r33-drift-car/
Hi, I'm after the following parts:
1. Do you have any front bar indicators? If so, what do they look like and how much?
2. I'm after the front inner guard lining thing that covers up the section from the front inner guard to the front bar. If how much?
3. Am after both your set of 27/30mm spacers, I'll give you $150 both. Is this ok?
How much to post to 3012 POST CODE in VIC?
1. keeping them with the front bar, which is staying with the shell
2. lost them years ago, ha
3. already got a buyer for the 30mm's mate
castor arms and tensionrods are the same thing though?
can you up load a pic of both sets so i can choose lol
Edited by tm_r33
you sure yournot thinking of sway bar.
do a google image search on 'r33 tension rod' and on 'r33 castor arm'
they the same thing bro
http://www.google.com.au/search?q=r33+cusco+tension+rod&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&hl=en&tab=wi&biw=1920&bih=1077
cusco tension rod $80 SOLD
d1 garage castor arms $80 SOLD
project mu slotted rotors (front) $100 SOLD PENDING PICK UP
d1 garage rear camber arms $100 SOLD PENDING PICK UP
racing gear n1 circuit coilovers $1,000 SOLD PENDING PICK UP
skyline rear strut brace $100 SOLD PENDING PICK UP
surge tank with lines and fittings $250 SOLD PENDING PICK UP
bosch 044 external pump $140 SOLD PENDING PICK UP
gtr wing $150 SOLD PENDING PICK UP
z32 afm $140 SOLD
hicas lock bar $40 SOLD PENDING PICK UP
    • I think my main complaint with your idea is that there is a veneer of idealism spread across it. You want the simple numbers to make it easier, but all they will do is make it easier for someone to come to the wrong conclusion because the fine details will kick them in the nuts. As it is right now, the tiny bit of arithmetic is NOT the obstacle to understanding what will fit and what will not fit. The reality of trying it is what determines whether it will fit. If you had a "standard rule" that R34 GTT guards have that magic 100mm space from the hub face to whichever side you were worried about, and someone said "excellent, this wheel is only 98mm in that direction, I'll just go spend $4k on them and jam them on my sick ride".....they would just as likely find out that the "standard rule" is not true because the rear subframe is offset to one side by a fairly typical (but variable) 8mm on their car and they only have 92mm on one side and 108 on the other.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
