Hi all ,
decided to strip my car down.
all parts are still on the car , car is complete for now.
if people are interested in the bigger bits such as motor/box then ill have it stripped down quicker.
someone come chuck a deposit on the motor and box :)
cusco tension rod $80
d1 garage castor arms $80
project mu slotted rotors (front) $100
d1 garage rear camber arms $100
kts rear cradle bushes $30
racing gear n1 circuit coilovers $1,000
nismo strut brace with cusco brake stopper $160
skyline rear strut brace $100
surge tank with lines and fittings $250
bosch 044 external pump $140
cusco half cage minus crossbar $300
sparco sprint fixed back $250
nardi deep corn copy $120
boss kit $45
hks evc5 ebc $300
gtr wing $150
rb25det motor minus turbo setup $1700 (needs new oil)
trust td05 with custom intake / greddy dump pipe / custom front pipe $1100
z32 afm $140
nistune rb20 ecu $400 (Tuned for engine setup with td05)
gearbox $900 (has slight whine)
18x8 /9.5 +45 $700
30mm bolt on spacers $100
27mm bolt on spacers $100
custom 2.5" blast pipes $250
Greddy boost gauge $60 (no light)
hicas lock bar $40
front mount intercooler with piping $250
signal straight through exhaust $600
r33 complete shell , with rego & plates $POA
cusco 2-way Mechanical Diff in housing $ 700
All parts sold as is
No warranty
Come inspect before buying
Postage at buyers expense
No COD
Will hold items if 20% deposit is paid on bigger items
If there is anything ive missed i will update the thread as it comes to my attention
contact: 0419 848 600
Edited by DamageInc
https://www.sau.com.au/forums/topic/362420-wrecking-r33-drift-car/
Hi, I'm after the following parts:
1. Do you have any front bar indicators? If so, what do they look like and how much?
2. I'm after the front inner guard lining thing that covers up the section from the front inner guard to the front bar. If how much?
3. Am after both your set of 27/30mm spacers, I'll give you $150 both. Is this ok?
How much to post to 3012 POST CODE in VIC?
1. keeping them with the front bar, which is staying with the shell
2. lost them years ago, ha
3. already got a buyer for the 30mm's mate
castor arms and tensionrods are the same thing though?
can you up load a pic of both sets so i can choose lol
Edited by tm_r33
you sure yournot thinking of sway bar.
do a google image search on 'r33 tension rod' and on 'r33 castor arm'
they the same thing bro
http://www.google.com.au/search?q=r33+cusco+tension+rod&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&hl=en&tab=wi&biw=1920&bih=1077
cusco tension rod $80 SOLD
d1 garage castor arms $80 SOLD
project mu slotted rotors (front) $100 SOLD PENDING PICK UP
d1 garage rear camber arms $100 SOLD PENDING PICK UP
racing gear n1 circuit coilovers $1,000 SOLD PENDING PICK UP
skyline rear strut brace $100 SOLD PENDING PICK UP
surge tank with lines and fittings $250 SOLD PENDING PICK UP
bosch 044 external pump $140 SOLD PENDING PICK UP
gtr wing $150 SOLD PENDING PICK UP
z32 afm $140 SOLD
hicas lock bar $40 SOLD PENDING PICK UP
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
