Hi all ,
decided to strip my car down.
all parts are still on the car , car is complete for now.
if people are interested in the bigger bits such as motor/box then ill have it stripped down quicker.
someone come chuck a deposit on the motor and box :)
cusco tension rod $80
d1 garage castor arms $80
project mu slotted rotors (front) $100
d1 garage rear camber arms $100
kts rear cradle bushes $30
racing gear n1 circuit coilovers $1,000
nismo strut brace with cusco brake stopper $160
skyline rear strut brace $100
surge tank with lines and fittings $250
bosch 044 external pump $140
cusco half cage minus crossbar $300
sparco sprint fixed back $250
nardi deep corn copy $120
boss kit $45
hks evc5 ebc $300
gtr wing $150
rb25det motor minus turbo setup $1700 (needs new oil)
trust td05 with custom intake / greddy dump pipe / custom front pipe $1100
z32 afm $140
nistune rb20 ecu $400 (Tuned for engine setup with td05)
gearbox $900 (has slight whine)
18x8 /9.5 +45 $700
30mm bolt on spacers $100
27mm bolt on spacers $100
custom 2.5" blast pipes $250
Greddy boost gauge $60 (no light)
hicas lock bar $40
front mount intercooler with piping $250
signal straight through exhaust $600
r33 complete shell , with rego & plates $POA
cusco 2-way Mechanical Diff in housing $ 700
All parts sold as is
No warranty
Come inspect before buying
Postage at buyers expense
No COD
Will hold items if 20% deposit is paid on bigger items
If there is anything ive missed i will update the thread as it comes to my attention
contact: 0419 848 600
Edited by DamageInc
https://www.sau.com.au/forums/topic/362420-wrecking-r33-drift-car/
Hi, I'm after the following parts:
1. Do you have any front bar indicators? If so, what do they look like and how much?
2. I'm after the front inner guard lining thing that covers up the section from the front inner guard to the front bar. If how much?
3. Am after both your set of 27/30mm spacers, I'll give you $150 both. Is this ok?
How much to post to 3012 POST CODE in VIC?
1. keeping them with the front bar, which is staying with the shell
2. lost them years ago, ha
3. already got a buyer for the 30mm's mate
castor arms and tensionrods are the same thing though?
can you up load a pic of both sets so i can choose lol
Edited by tm_r33
you sure yournot thinking of sway bar.
do a google image search on 'r33 tension rod' and on 'r33 castor arm'
they the same thing bro
http://www.google.com.au/search?q=r33+cusco+tension+rod&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&hl=en&tab=wi&biw=1920&bih=1077
cusco tension rod $80 SOLD
d1 garage castor arms $80 SOLD
project mu slotted rotors (front) $100 SOLD PENDING PICK UP
d1 garage rear camber arms $100 SOLD PENDING PICK UP
racing gear n1 circuit coilovers $1,000 SOLD PENDING PICK UP
skyline rear strut brace $100 SOLD PENDING PICK UP
surge tank with lines and fittings $250 SOLD PENDING PICK UP
bosch 044 external pump $140 SOLD PENDING PICK UP
gtr wing $150 SOLD PENDING PICK UP
z32 afm $140 SOLD
hicas lock bar $40 SOLD PENDING PICK UP
