hey guys just wonder what type of power ill get out of my rb20det with this set up
ENGINE 100% stock
- Top mount GT35 Turbo, 0.63 turbine housing, Compressor housing: A/R .70 with 100mm air inlet ( boost 3000-4000+?)
or WS-0448 Turbo
- 38mm external wastegate
- 550cc injectors
- Yellow jacket coilpacks
- NGK R Iritop 7 spark plugs
- Bosch 040 intake fuel pump
- HKS SSQV BOV Plumb back
-Z32 afm
- Big front mount
- full 3" zorst
- and a nistune.
ill be happy with 200-300kw
what RPM do you think this will start boost and reach max boost?
Will be using stock ecu for a while.
POST how much hp you think will come from this!
Thanks
Edited by swirto
https://www.sau.com.au/forums/topic/362446-rb20det-max-power/
  • Replies 66
Stock ECU - forget about anything occuring mate. Dont even wind up the boost until you get a tune.
GT35 - boost around 4,000-4,500 even with a .63, might be later. Hard to say.
You'll be lucky if you make 300rwkw on 20psi
You'll need to throw 25psi+ down it's neck to get anywhere with a 700hp turbo with a choked rear end. You'll also need a bigger exhaust for that turbo. 3" might not get you there.
All that said, you've probably realised a theme - buy something that is not a 700hp turbo for 250rwkw and be much better off for it. I think it's a very bad choice of turbo.
There are loads of better choices:
3071 - 260rwkw
TD06 - 270rwkw
HKS2530 - 230rwkw
Also forget the Iridi plugs, waste of money. Buy normal copper.
That's quite a big turbo with a tiny rear end for a tiny motor. You'll get more investing in an RB25DET motor and a little more boost. Seriously, an RB25DET stock turbo 13 psi with a tune, pump, injectors and what not will see about 220rwkw.
3071 - 260rwkw
TD06 - 270rwkw
HKS2530 - 230rwkw
This.
Recommend this item:
http://cgi.ebay.com.au/Turbocharger-Kinugawa-TD06SL2-20G-w-T3-V-Band-Housing-/280657315892?pt=AU_Car_Parts_Accessories&hash=item41587ac834
Once you start getting past 220-230 rwkw with a rb20 you'll get nothing but lag, the best turbos out there ie least amount of lag for a 20 will get you 230 rwkw max, once you start chasing more that means bigger turbo = lag, and i mean piss you of annoying lag trust me. The turbo you listed will be to laggy and is more suited to a 2.5 or 3 litre.
If you have the cash invest in a 25, pretty easy to get a reliable 260-300rwkw where as a 20 is kinda to restricted for anything over 230.
I'm sunning a standard turbo highflowed and have 219 rwkw and its not to laggy, still more then standard of course but no where near as bad as say a 33 highflow. I make full boost by around 4-4.5k, i personally think around 210-230 is perfect for a 20.:thumbsup:
A hks 2535 would prob get you closer to 240 or more but unsure how it compares lag wise to the hks 2530 which is a proven winner on a 20.
I should ad that e85 could be the way to go to, theres a guy on here who got 265 rwkw from his 20 with similar turbo as mine, just he has spent a fair bit of time on rb26 inlet manifold and a few other things, but still a pretty good effort.
Edited by eightsixboy
A proper trust TD06L2 has been proven time and time again...
If you think it is really laggy then you should not have an RB20. It is a worthwhile compromise.
If you still want it for daily duties and a little track then you can't go past the HKS 2530 option mentioned or the 2871.
