  • Replies 66
Hmmm ok, i always thought the inlet manifolds on the 20's were shit, maybe i was thinking of the redtop or something. Just weird how you rarely see a 20 make more then 230-240rwkw, i know not wanting to put a massive turbo on is a big reason due to lag but if the std inlet is not a restrition then whats holding these motors back? 25's seem to make more power easier, mate at work has almost 300rwkw with a unopened motor, just a 3076 (i think) and the usual supporting mods, i know been a 2.5 over a 2 littre helps but still.
Yea sounds weird if the 2535 is running out of puff after only 6.5k, should be good almost to redline. I think even the smaller 2530's are good till about 7k then they fall of.
Might have something to do with the cams, your not running cam gears are you?
yeh HKS cam gears aswel
this is mates track car down here in VIC
although rb24 it still retains the standard rb20 inlet manifold, 400KW @ wheels
And some people wonder why imports have a bad name with the general public.
Its not a skyline so its ok :nyaanyaa:
I think with the 20's you have to have a compromise between power and response, nothing you can do about the lag and as roy said it can be an advantage having less torque, with a good turbo setup and been able to have you foot planted mid corner and still getting traction is a good thing, just maybe not as fun on the street.
  • 2 years later...
I'm with you on that. That guy is a f**king idiot. It sucks that we all shit canned in the same group as him.
Settle down hardparkers, he would look like a muppet if he's got drift stickers and a huge T wing and the car had 100% tread. Personally i hate getting canned in the "DRIFTSCENE" because today's driftscene is filled full of people who put stickers on their cars, chinese bodykits, fartcannons and sit at meets with 100% tread saying IF i was to do a burnout i'd light up the street.
Anyone who drives a skyline like a commodore should sell their car and buy a commodore.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
