From personal experience, you should get about 220 - 240 rwhp depending on your exhaust and pod - so roughly 165 - 180rwkw. I got 239.8HP (i lost the damn graph or i'd post it) with stock s2 with pod, full zorst, 10 psi and an SAFCII tune-up. That was done in shootout mode @ reputable dyno here in WA (SST).
https://www.sau.com.au/forums/topic/36247-what-power/#findComment-723106
Same(ish) - sst dyno i got 254rwhp.
stock turbo and cooler, K&N filter in std box, otherwise same as seriesIIGTST
now in melbourne i got 160rwkw at complete auto with a sick fuel pump, apparently it was leanign out lots at the top end. so yeah 160-180kw sounds fair
https://www.sau.com.au/forums/topic/36247-what-power/#findComment-723143
LOL
Seeing a friends RB20 SIl80, stock turbo, full 3" exhaust, fmic, Blitz EBC & CAI makes 160kw @ 12.5psi you seem to be tad pessimistic.
Depends on the dyno I guess
I've been to 5 dyno days and watched over 130+ cars (mainly R33's). I'm quite confident in my answer.
Although as you said... it mainly depends on the dyno :)
https://www.sau.com.au/forums/topic/36247-what-power/#findComment-723680
i got air filter, turbo back zorst, boost 10psi, bov and im on 172rwkw
ben...
I got the same mods (except 12psi not 10psi and also a fmic) still standard turbo and ECU and on 3 different dyno's I got
- 203rwkw
- 189rwkw
- 180rwkw
go figure....
https://www.sau.com.au/forums/topic/36247-what-power/#findComment-724491
Guest INASNT
with no safc or anftermarket comp and no fmic u will be getting around 160 on a friendly dyno.
Just remember if u pay a shop to do some work for you and then see how much power it has gained they will almost always fudge a few more kw into your run just so it looks like the $$ you hand over was worth it.
https://www.sau.com.au/forums/topic/36247-what-power/#findComment-724533
hey guys, just wondering... i have a series 2 R33 GTS-T. mods are bov, pod, turbo back exhaust and 11psi its running. just wondering what sort of power i should be getting approximately on the dyno??
cheers
I got '98 S2 GTS25t with K&N panel in stock airbox, turbo-back HKS Super Drager, 11PSI. so I have had quite a bit of interest in this thread. I will be getting along to a dyno-day B4 2 long and will then have the answers.
The car is just SOOOO much better than stock like this. Much more fun to drive.:cheers:
p.s. being a 1998 model, there is a slight chance that my engine is actually a NEO6 internally. I have not been able to find out for sure but I guess if it goes on the dyno and makes about 15rwkw more than expected I will have an answer.
Fingers crossed
https://www.sau.com.au/forums/topic/36247-what-power/#findComment-724660
On the average Dyno Dynamics dyno I'd expect to see around 155-165rwkw with those mod's. Much more than that and I'd be very happy, or slightly suspect of the dyno. Atm you have no control over your factory ECU, so it'll be the deciding factor.
https://www.sau.com.au/forums/topic/36247-what-power/#findComment-724688
    • They work on really anything track related now. They do my mates r35 gtr and it's a weapon of a car.
    • I use the penrite 600f in my cars and have had no issues even at Townsville v8s when I drove that but I bled fluid end of day for just in case. Good value and a about 38-40 on sale. Use castrol srf on the supercars and no need to Bleed brakes over a race weekend. Do the 1000km with no issues. Over 120 a bottle I seen at repco. A quality brake pad is always a good starting point the ebc stuff I've seen let go after 2 sessions with heavier cars. I'd be going to a decent track pad and maybe those porsche air guides on the control arm to help with some air over the rotor. Helps on 86/brz with stock callipers.
    • yeah I've never understood that either.... And to answer an earlier question, I write the date on open bottles and throw them if more than 12 months old (which they almost always are, because I don't need to bleed them unless I'm changing lines/calipers etc in between)
    • Nah, the one that hit the boot was a big steel locker, around 6 foot height, 4 foot wide and 2 foot deep, empty it weighs about 15kg and had about that amount of stuff in it The photo didn't give a good representation of the actual damage, the large ding on the passenger side was about a inch deep, the one on the driver was about 1/2 inch deep, right on the curve, where the inner boot frame doesn't let you get behind it with a dolly Basically the same issue with getting behind the damage on the centre of the boot We could have filled it all with bog, but my OCD would be triggered every time I looked at it, knowing what hides beneath  As for the locker, I did get the shits with it and put it in the scap metal bin, but, I pulled it out and it is now sitting in the garage at home full of car servicing stuff, cleaning gear and random tools, it's going to pay for it's indiscretions
    • Whilst I typically don't cheap out on things, if I can save some money, like $1000, on a clean straight panel, that gives me $1000 to spend on other stuff, basically free money really 🤔 🤣
