  • Replies 53
Hi,
You said you are interested in buying a Type R. Would you be interested in a late model 1997 Honda Prelude VTI-R ATTS(Active Torque Transfer System)? basically means an active LSD unlike a standard prelude. It has lots of sensible perfromance mods. and is faster than a type R. Makes 108Kw at the wheels!
-1997 Honda Prelude Vti-R ATTS
-90,000Km
-Photo's can be e-mailed if you are interested
The car has the following modifications:
Full factory Honda body kit(including wing on bonnet, very rare)
AEM adjustable cam gears
AEM light weight pulley kit
Neuspeed short shifter
Neuspeed sport springs (1.7" drop)
OBX 4-2-1 stainless steel extractors
Stainless steel dual tip rear muffler (no exhaust drone at all)
Magnecor KV85 ignition leads(made in U.S.A not Aust.)
JUN ultra light weight flywheel (5kg, factory flywheel is 10kg!)
Daikin sports clutch (not brass button)
Falken Azenis ST-115 tyres on the front
The car has been dynoed to tune the adjustable cam gears and makes 108Kw at the wheels. I have the dyno sheet for proof. It was tuned by Croydon Racing in Silverwater, so you’re guaranteed the car has been tuned perfectly. It is an ATTS model so it has an active LSD unlike a standard prelude. This is a fast car for what it is and is very nice to drive.
I have spent about $10,000 on the car(parts & labour) most of these parts where imported by me from the U.S.A and a very expensive. All parts were professionally fitted. The car is in excellent condition.
If you would like to ask any questions or arrange to see the car, e-mail me or you can call me on 0431 064 288.
Thanks,
George.
My e-mail address is [email protected]
What is the condition of the paint like? Was it rubbed back properly when sprayed or just put over the original colour? Have you got access to the paint code in case it needs a repair in the future? Thanks, sorry about all the questions!
awsome skyline....trying to get hold of some of those rims myself. An by the looks of your bodykit its a Bomex front bar, Jun sideskirts, and Trail rear bar....nice matching, looks neat.....but not a full bomex kit.
cant believe it hasn't been snapped up yet. Good luck with the sale...or possible swap
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
