  • Replies 53
Hi,
You said you are interested in buying a Type R. Would you be interested in a late model 1997 Honda Prelude VTI-R ATTS(Active Torque Transfer System)? basically means an active LSD unlike a standard prelude. It has lots of sensible perfromance mods. and is faster than a type R. Makes 108Kw at the wheels!
-1997 Honda Prelude Vti-R ATTS
-90,000Km
-Photo's can be e-mailed if you are interested
The car has the following modifications:
Full factory Honda body kit(including wing on bonnet, very rare)
AEM adjustable cam gears
AEM light weight pulley kit
Neuspeed short shifter
Neuspeed sport springs (1.7" drop)
OBX 4-2-1 stainless steel extractors
Stainless steel dual tip rear muffler (no exhaust drone at all)
Magnecor KV85 ignition leads(made in U.S.A not Aust.)
JUN ultra light weight flywheel (5kg, factory flywheel is 10kg!)
Daikin sports clutch (not brass button)
Falken Azenis ST-115 tyres on the front
The car has been dynoed to tune the adjustable cam gears and makes 108Kw at the wheels. I have the dyno sheet for proof. It was tuned by Croydon Racing in Silverwater, so you’re guaranteed the car has been tuned perfectly. It is an ATTS model so it has an active LSD unlike a standard prelude. This is a fast car for what it is and is very nice to drive.
I have spent about $10,000 on the car(parts & labour) most of these parts where imported by me from the U.S.A and a very expensive. All parts were professionally fitted. The car is in excellent condition.
If you would like to ask any questions or arrange to see the car, e-mail me or you can call me on 0431 064 288.
Thanks,
George.
My e-mail address is [email protected]
What is the condition of the paint like? Was it rubbed back properly when sprayed or just put over the original colour? Have you got access to the paint code in case it needs a repair in the future? Thanks, sorry about all the questions!
awsome skyline....trying to get hold of some of those rims myself. An by the looks of your bodykit its a Bomex front bar, Jun sideskirts, and Trail rear bar....nice matching, looks neat.....but not a full bomex kit.
cant believe it hasn't been snapped up yet. Good luck with the sale...or possible swap
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
