Just wondering if anyone has used one, and how the knock side stacks up against the gizzmo and others. And how fast/accurate the a/f side of it is.
They are about $950 delivered from nengun, which is pretty good value if you add up a gizzmo knock box, and a a/f meter.
https://www.sau.com.au/forums/topic/362517-hks-af-knock-amp-2/
  • 1 month later...
They are very good, ive had a few jap cars come over with them installed but bear in mind a quick search and you can now pickup the gizzmo one for about $500 (usa) and the wideband for $150 ish... market has dropped its pants in the usa :P if it is a permanent install in one car then the HKS unit is a nice one stop solution and its a got good ergos as a dash mounted unit.
TBH i have been looking @ buying one and implementing it into our dyno (with longer flying leads for the dual knock and 02 sensors) as the unit also has a analogue knock output... would be nice to plot it against afr / lambda to have a visual as well as a audible warning.
I had the gizzmo wired in to the dyno but it required a usb connection to function so im logging on two pc's.. one in the car the other was the dyno unit... no point as it was too bulky.... so i removed it and got the gibson developed knock box which is just as good as the gizzmo unit but has noise cancelling headphones, only drawback is it has no outputs... and is $1100
would you run bosch sensors, or do the oem ones do the job?
knock sensors?
if so i would look at the application, ie fixed or multi car setup. For me it needs to move from car to car daily so i would use new bosch donuts (which wire up different to nissan oem donuts) and this allows me to pick locations on various cars as they are easy to make adapters for..
If it was to be a permanent install i would look at the ecu, if it has knock feedback or similar i would fit up a secondary pair of bosch sensors. If the ecu is deaf to knock sensors i would remove the std ones and fit new bosch ones to the factory position.
yeah knock sensors. Thanks for that, it'll probably live in my race car for 90% of the time, the ECU (PS2000) is knock deaf. But I want to run a knock input into my racepak dash for logging and warning.
I don't mind having to mod the wiring to change sensors. Good to know the HKS will be a good option.
    • Hey all, not sure how active SAU is anymore but will ask away anyways. Just wanted to get some experience on the 2008 model GTR CBA model.  I've hit that age in my life (43) where I'm like fk it time to get my dream (midlife crisis) car. Looking at importing one in and seeing if these can be reliable if the main flaws are fixed up. Plan is to keep money aside to do the following straight off the bat to future proof it: * install a stage 1 rebuilt trans with all new bits and pieces.  * install a new Bellhousing from the later model GTRs. Or potentially an upgraded stronger version like MAD or ATR. Besides the above two things and typical maintenance items anything else you'd recommend doing.   Been speaking to a few people and the engine on these are very reliable apparently. But keen on the view of the community here. Hoping to find a nice grade 4.5 with low mileage in Grey. I'd go black but swirls too easy. Look forward to your responses and feedback. Cheers
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
