look great, but..
not trying to be a naysayer but isnt this what the rubber seal under the bonnet is for?
Im not sure mate...but as you said looks about a million times better and all the big name companies make them so im sure there must be something there lol
wow, you own a 34 GTR and you cheaped out on a relatively low cost item. oh well, at least ur DIY looks good!
As i first stated I hate spending money on rice and $150 for a 1.5mm piece of alloy is absolute bullshit. I prefer to save my money for things like the jun forged flywheel and clutch I just had installed...or some turbos and cams etc.
I dont mind spending money where it counts, and thanks for stating it looks good.
I wouldnt say fabricating a bit of kit for your car is cheaping out, more like common sense, most stuff you build is better than some overpriced brand named POS.
Nice work mate, keep it up.
People who can do, people who cannot talk alot.
Haha, wasnt trying to bag him out. As I said, he did a great job.
I'm a fabricator by trade so could certainly make anything I needed if I felt so Inclined.
Obviously we just have different points of view on car modifying. I like having brand name aftermarket parts on my cars, and I respect that you might not.
And while I don't agree that "most" peoples DIY is better than brand name gear(in this case it is certainly as good as anything he could of bought), I do agree that a lot of brand stuff is overpriced :S
Personally I would of got a garage defend CF cooling panel :D
i made this for my 31, although i dont run the standard latch i have bonnet pins its made out of 3mm stainless but if anyone wants one i cant have one lazer cut and folder for $50 and hole for the latch cut out aswell, pm me if needed.
I hate "brand name" stuff and will only buy it if I absolutely have to. I get more gratification out of working on my cars myself so I will make whatever I can. The only things I don't do are tuning and suspension setups.
Any of you fabricator type people got any tips/hints/suggestions for painting the ally? I could buff it up but not really a fan of the "bling", would prefer to paint it matt black!
Scotch brite for mechanical etch and removal of the oxidisation, and a spray can primer that states its suitable for aluminium.
you could have bolted the cardboard in for lolz
For a second there I thought he was serious about the cardboard one... then I scrolled down further. :laugh:
and I'm one of them that purchased the cheap crappy Hi Octane one which ended up cracking....
Mine was f**ked before I even fitted it to my 33 :(
i would be interested in seeing the inlet temps at the filter with and without the cooling plate. ive seen these plates for sale alot and often wondered if they would block the flow of cool air to the cool air intake fitted to the airbox and make it suck in hot air from the engine bay. i might have to make one up and see if theres a difference.
but on a different thought, would you really need one?? i guess youd need it if your having overheating problems.
You can fell the difference. Grab your filter with your hand before and after. And just like everything that you do to your car, you don't need it. But it does increase power ;). Colder air/ more dense= more oxygen/more bang for buck
There are two functions for these covers...
1) To force the incoming air through the radiator to aid in cooling instead of going around and over it (It will go over once the bonnet rubber loses its "springyness" and doesn't seal properly.
2) For looks. They're designed to hide the "uglyness" of seeing the back of a FMIC and AC condenser/radiator...
Ahhhh bugger. LOL i had this one and the Heat Shield one open and i replied to the wrong one hahaha. Yes Believe Matt. Im also looking at making some panelling for the side and bottom of the main feed from the front bar to try and help a bit more.
  • 1 month later...
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
