R33 Gts-T Build
Well, Nissan says So factory expects 0.11Mpa or or 110kpa or 1.1bar or 16psi (which feels low to me, but there you go)
Ok thanks guys that is what i thought and learned from all the comments/videos too. If i want to BoV i need/want to have standalone ECU 馃檪 And the bypass valve tge car has is good for stock(little bit more) power.
By myrbgivesmeheadaches 路 Posted
Wait so is it heaps low or double what it should be..? -
By Dose Pipe Sutututu 路 Posted
That's heaps low tbh Is your oil pump factory? -
You typically expect about 100 kPa at idle - 1000 rpm. You're in the region of double that.
