  • Replies 99
NEWS UPDATE:
hasnt been much happening to the car recently as i am trying to save up some mulah! :)
but i sold my GTR wing to a nice bloke on here who is building up his 33 in W.A. a few days later i found all jap in brisbane had a carbon fiber drift style boot lip, so i went and picked that up, brought it home and threw it on the car straight away, im pretty happy with the look of it so far, within the next few months the car will be getting a full respray with a kit and all, most likely going a darker colour so the carbon fiber blends in a bit better. but for now im very happy with the look of it :)
also found this video which is pretty interesting on regarding the ongoing debate over engine oils. i think ill be using nulon from now on :)
thanks for looking
SO!! just wanting some peoples opinions on here, i am wanting to change my turbo from this current bush bearing T04E oil cooled turbo to a garrett something turbo, with these mods what do you think would be a good choice? 3076??? i am after response and pull trying to minimize lag.
K GO!
Hey Ricky :wave:...im gettin a high flow 3076 core in mine by next week...will let you know how I go :yes: ......if you can wait that long :mellow:...comes with water n oil lines...n pretty stealth if its a daily and your worried about cop issues and not chasing crazy power
Also explain "getting sick of HICAS".....how helpful is this bar etc?? I have read about HICAS and I know what it is..how it works..how u get the bar put on etc etc...but I want to know first hand experience. :thumbsup:
Edited by jez NF
hey jeremy,
if you dont mind me asking, how much is that turbo costing you? im just finding the t04E a little unreliable power wise at the moment want something with a bit more punch, was thinking a gt3582r .82 rear ex housing.
the HICAS is rear wheel steering unit, which is located right behind the diff if you look under the car, by removing the HICAS unit and putting in a lock bar as i have done disables the rear steering and makes it solid which is easier to drift on, better on tyre wear etc. and cheap to buy, took me about 25 mins to install.
hey jeremy,
Was quoted around the $2000 mark...good value for money in my opinon...good for 350 - 370 at the wheels on a decent tune...standard bolt on....I will prob settle for 350 as I prefer running "safe"....HKS and the Gt-rs range are better for lower end responsiveness but can get quite expensive...also difficult to source here in WA.
Yeah I know what HICAS is "supposed to do" and what it is etc etc..just want to kno how it feels driving wise...as in would you lose the back before and find it awkward to reign in.....would you find the correction tough to predict on corners?? Is it a lot smoother now?? How is the power steering?? at low speeds? at high speeds? do you hold lines better?? etc etc :nyaanyaa: Agree on the cheap fix bit...it is quite a cheap mod (if it works)
ok so i have been doing a bit of research on the various turbos i can get. the cost to get my current T04E rebuilt with ball bearing cartirdges is just shy of 2k which i think is way too much, i can get a genuine garrett for that much.
seems like the better turbo to with is a Garrett GT3582R with a .63 or .73 rear housing externally gated.
your thoughts?
ok so i finally made up my mind on a GT3076R with .63 rear housing externally gated, unfortunately i wont have the $$$ until tax time next year :( but until then i will be doing heaps of little bits and pieces to have everything ready so the new turbo can bolt straight on and get tuned.
thanks for the help on here guys!
Jeremey: i have only driven the car 2 times since i put the lock bar in, it feels much better and more stable and will save the rear tyres from suffering inside wear and tear.
so i got bored the other day and decided to put my fab skills to work, got sick of hearing my #1 muffler hit on every speed bump because it was hanging too low.
so out with the old
and in with the new...small piece of 3" s/s tube made a bit shorter to pull the exhaust up a bit higher for more ground clearence.
  • 4 weeks later...
Quick update! not all that much has been happening to the car in the last few weeks, found a huge boost leak thanks to a split rubber joiner.
I finished of fabricating a surge tank from 316 stainless steel with 3/8 fittings, bosch 044 fuel pump is on the way.
also have ordered a deep dish steering wheel and boss kit along with a dildo shifter!
here are some pics to keep you going!
Surge tank (still needs to be polished up a bit more)
boss kit and steering wheel
quick pic
Oy man.....Is your steering wheel going to be blue???
Sorry for picking up on something as trivial as the colour....but seriously blue on your car??? why?? How about black with the little yellow bit..that will look quite awesome...and match your rear lip spoiler?? and interior trim !!
hahaha sorry thats the only pic i could be bothered getting, i just ordered the boss kit atm, still picking a steering wheel, in about 5 mins ill post up a pic of my options. let me know what one you think is better, im thinking genuine cough momo :P black suede with red stitching :)
    • looking forward to your t56 swap man its a game changer if it works!
    • So, when are you trying the new GR86 or BRZ?
    • Uncle Duncan Yeap, FI Interchiller  Works well, normal IAT's cruising with the WTA only went from 50°c+ to 25-30°c with the interchiller  Before, when on it hard, the IAT would see 80-90°c, now, the highest has been was around 38°c IIRC IAT is measured under the blower hat I recommend it for the street or strip where your only on it hard for 10 or so seconds, but it wouldn't be efficient for sustained track use as it would heat soak from the AC turning off or whatever it does during WOT to protect the compressor It really needs the AC running for it to not heat soak and keep the WTA coolant chilled My WTA coolant temps when just cruising is around 2°c
    • Hey Mark...sorry to interrupt your career change to hair dressing... but...did you ever fit the interchiller to the commodore, and if so how was it? And, who made it?
    • I've been pondering this, I really enjoy the convertible thing, for me, it's like riding a motorbike, without all the issue of riding a motorbike, mainly, my old sore arthritic joints getting beaten up, and, being able to do it in shorts and a T-shirt and not needing a helmet and all the other gear required, especially like wearing jackets and pants in the summer, or needing 6 layers of cloths in the winter, or not having wet weather gear handy when your 100km away from home on the bike when it decides to start raining As for the hard top and its Coupe look, whilst I do lose all that open top feeling that I really enjoy, from my experience with the NB with a detachable hard top, the cabin is a much nicer place to be, the difference in noise for one, a hard top quietens down the interior, alot, with the soft top up or down it's pretty noisy, which, after 5 or so hours, can get tiring But, as you stated, the detachable hard top totally changes the look of the car, in a really good way, and for me, the look of a detachable hard top is so much better than the PRHT which looks more like a after thought with its weird bulbous rear roof line For me, the minimal effort of putting in on, or storing it after removing it, is well worth the time and effort for the look alone And yes, I'm sure the next owner will be grateful for it as well.......
