  • Replies 99
NEWS UPDATE:
hasnt been much happening to the car recently as i am trying to save up some mulah! :)
but i sold my GTR wing to a nice bloke on here who is building up his 33 in W.A. a few days later i found all jap in brisbane had a carbon fiber drift style boot lip, so i went and picked that up, brought it home and threw it on the car straight away, im pretty happy with the look of it so far, within the next few months the car will be getting a full respray with a kit and all, most likely going a darker colour so the carbon fiber blends in a bit better. but for now im very happy with the look of it :)
also found this video which is pretty interesting on regarding the ongoing debate over engine oils. i think ill be using nulon from now on :)
thanks for looking
SO!! just wanting some peoples opinions on here, i am wanting to change my turbo from this current bush bearing T04E oil cooled turbo to a garrett something turbo, with these mods what do you think would be a good choice? 3076??? i am after response and pull trying to minimize lag.
K GO!
Hey Ricky :wave:...im gettin a high flow 3076 core in mine by next week...will let you know how I go :yes: ......if you can wait that long :mellow:...comes with water n oil lines...n pretty stealth if its a daily and your worried about cop issues and not chasing crazy power
Also explain "getting sick of HICAS".....how helpful is this bar etc?? I have read about HICAS and I know what it is..how it works..how u get the bar put on etc etc...but I want to know first hand experience. :thumbsup:
Edited by jez NF
hey jeremy,
if you dont mind me asking, how much is that turbo costing you? im just finding the t04E a little unreliable power wise at the moment want something with a bit more punch, was thinking a gt3582r .82 rear ex housing.
the HICAS is rear wheel steering unit, which is located right behind the diff if you look under the car, by removing the HICAS unit and putting in a lock bar as i have done disables the rear steering and makes it solid which is easier to drift on, better on tyre wear etc. and cheap to buy, took me about 25 mins to install.
hey jeremy,
Was quoted around the $2000 mark...good value for money in my opinon...good for 350 - 370 at the wheels on a decent tune...standard bolt on....I will prob settle for 350 as I prefer running "safe"....HKS and the Gt-rs range are better for lower end responsiveness but can get quite expensive...also difficult to source here in WA.
Yeah I know what HICAS is "supposed to do" and what it is etc etc..just want to kno how it feels driving wise...as in would you lose the back before and find it awkward to reign in.....would you find the correction tough to predict on corners?? Is it a lot smoother now?? How is the power steering?? at low speeds? at high speeds? do you hold lines better?? etc etc :nyaanyaa: Agree on the cheap fix bit...it is quite a cheap mod (if it works)
ok so i have been doing a bit of research on the various turbos i can get. the cost to get my current T04E rebuilt with ball bearing cartirdges is just shy of 2k which i think is way too much, i can get a genuine garrett for that much.
seems like the better turbo to with is a Garrett GT3582R with a .63 or .73 rear housing externally gated.
your thoughts?
ok so i finally made up my mind on a GT3076R with .63 rear housing externally gated, unfortunately i wont have the $$$ until tax time next year :( but until then i will be doing heaps of little bits and pieces to have everything ready so the new turbo can bolt straight on and get tuned.
thanks for the help on here guys!
Jeremey: i have only driven the car 2 times since i put the lock bar in, it feels much better and more stable and will save the rear tyres from suffering inside wear and tear.
so i got bored the other day and decided to put my fab skills to work, got sick of hearing my #1 muffler hit on every speed bump because it was hanging too low.
so out with the old
and in with the new...small piece of 3" s/s tube made a bit shorter to pull the exhaust up a bit higher for more ground clearence.
  • 4 weeks later...
Quick update! not all that much has been happening to the car in the last few weeks, found a huge boost leak thanks to a split rubber joiner.
I finished of fabricating a surge tank from 316 stainless steel with 3/8 fittings, bosch 044 fuel pump is on the way.
also have ordered a deep dish steering wheel and boss kit along with a dildo shifter!
here are some pics to keep you going!
Surge tank (still needs to be polished up a bit more)
boss kit and steering wheel
quick pic
Oy man.....Is your steering wheel going to be blue???
Sorry for picking up on something as trivial as the colour....but seriously blue on your car??? why?? How about black with the little yellow bit..that will look quite awesome...and match your rear lip spoiler?? and interior trim !!
hahaha sorry thats the only pic i could be bothered getting, i just ordered the boss kit atm, still picking a steering wheel, in about 5 mins ill post up a pic of my options. let me know what one you think is better, im thinking genuine cough momo :P black suede with red stitching :)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
