  • Replies 72
Depends on where on the pillar its mounted. Tim Ireland told me if its on the pillar, as long as its no where the head can reach its ok. Went on to say they are otherwise illegal due to an increased risk of head injury in an accident (Of course it will Tim, just before your head goes through the A pillar)
https://www.sau.com.au/forums/topic/36255-2532/page/4/#findComment-770783
whooo i installed my power up 2 stage boost controll this week end
I cant boost it up yet because my boost gauge has not arived yet
dose any one know what 7 mmhg's on the factory boost gauge = in PSI
and also doese it matter which vaulve on the dsbc you use for the low and high settings
thanx guys you have been a great help so far
https://www.sau.com.au/forums/topic/36255-2532/page/4/#findComment-774556
According to some sources, the stock intercooler can be responsible for up to 7psi drop at higher revs, so this means you are actually producing 20psi boost to see 13 at the plenum.
I wouldnt do it. Keep the boost around 10psi with a stock cooler if you want the turbo to last. This is pretty much the safe limit for a R33, may be a bit different for a 32 though.
https://www.sau.com.au/forums/topic/36255-2532/page/4/#findComment-775368
sorry dont know.
Highly recommend you just find a good tuner and pay them whatever they want to do a good tune - if you get bargain prices, you get a 'bargain' tune - think about it, if someone asked you to do a tune, and it would cost you say $500 of your time, but they only wanted to pay $200, would you still do a full tune, or just a $200 dollar tune?
I have found you get what you pay for, and the sweet taste of a cheap tune will wear off pretty quickly when the car isnt running the way you know it should. I had to learn the hard way:p
https://www.sau.com.au/forums/topic/36255-2532/page/4/#findComment-775700
yeh i was only going to talk to the top tuners eg boostworx teilbrooks and rpm and maby
morpower i dont know yet i havnt herd much of them
im not so much worryed about the price i was going to ring them tell them what i want ask them a few questions and se which had the best customer service and most willing to help
i hate it when mechanics snub you off and try keep you in the dark soon as that happens i usualy pull my car right out and go to the next shop
i had one place want to pull my steering rack out and send it to melb to get recond but i did not belive there was any thing wrong with it so i took it to bedders in modbry and the said that it was fine all the other namless place wanted was a few extra bucks i think
but me no that silly
https://www.sau.com.au/forums/topic/36255-2532/page/4/#findComment-776424
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
    • Sounds like it is rotational in the driveline. CV? Tailshaft CB? Also.....didn't you just pay to have that bit painted and put on the car?
    • Yeah, when I dialled my idle down, given how much time I spent idling at the lights in traffic on my daily commute, the effect on overall fuel consumption was absolutely noticeable.
