How can I get this importer punished....look what i Found!
http://www.j-specimp...-133266686.html
A nissan silvia s15, clean, white and 89,000kms from Japan......for 13 grand (obviously an old ad)
Now you may be thinking, La Bomba is an idiot...
BUT!!!!!!!!!!!!
This is where it gets interesting
http://cgi.ebay.com....=item4158ce8983
The same car (notice the nismo sticker and the number plate at the same slant angle) is advertised by Edward Lees Japanese Auto Centre for $22,000
with 58,000kms and for a f**king 9 grand profit..........So obviously THEYVE WOUND THE K's back... by 31,000kms hahahhahahaha omg
I want to go there and show them the yahoo auction and threaten to take them to court unless i get the car for a nice price ;) watdoidonow.jpg
Edited by WanganMidnight
  • Replies 75
Wangan, not smart even for you....
$9,000, why not charge that much.... They certainly are not selling cars for the love, no one does.
Edited by Shazza24
They would of got it for around 10-11 therefore adding 12 grand.... which is good profit, however the point is they wound back the odomoter 31000kms.
Are you thick?
How much do you think transport from Japan, registration and compliance cost? $20?
It all adds up if the car sits on the lot a while they have to reduce the price If someone habits with them thy have to reduce the price, businesses survive off profit
It's how the economy works
Edited by stig mick
Fine, i will run you into the ground...
You forget: Taxes/Tariffs, Compliance, Business overheads, wages, lease/rent, insurance, etc
As for the other point you are trying to make it is called "Defamation" as you are accusing someone without concrete evidence(your going off what websites say, it could be a simple mistake FFS) and their reputation could be +11ty more than yours, on top which then leaves you with: Court costs(theirs and yours), and anything that the court finds in their favor for perceived damages= $$$.
You are no longer original or inventive as a troll, it's time for you to come out from under that bridge....
Edited by Shazza24
U can't touch this
Look man u can't touch this
You'll probably get hyped boy
'Cause you know you can't u can't touch this
Ring the bell school's back in break it down
stop... Ban time
As for the other point you are trying to make it is called "Defamation" as you are accusing someone without concrete evidence and their reputation could be +11ty more than yours, on top which then leaves you with: Court costs(theirs and yours), and anything that the court finds in their favor for perceived damages= $$$$$.
It is obvious that they are the same car.
It even has the sticker in the same place and the same rims for crying out loud!!!!!!! as well as the same strut brace and front guards lol
Mods can you please edit my original post and take away the ebay link and name of the dealer caus so i dont get sued for my $300 life savings lol, or whoever originaly quoted my original post unquote me so i can edit
It's called "Bankruptcy" get used to it.... :rofl:
I have seen web ads for cars in caryards that say "No ABS" then you get there and what do you know it actually has ABS... Just a simple mistake.
IMO if you buy a car without a solid service history( no to mention the papers with last two owners in japan and all that jazz) what do you expect? You could also buy a car privately and who knows what the previous owners have done to it?????
Dude, you're in BIG strife lol
omg thats definately not what i wanted to hear......somone get a moderator to delete this quick!!!!!!! ERASE IT SOMEONE! omggggggg
Guest
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
    • It seems you'd like your Skyline to go to a great home, that can keep it as a beautiful museum piece.  I feel I can provide the perfect place for it, however, I'm not sure I can justify so much money for a Skyline that has only been crashed 3 times. Due to this and market prices, would you be against me buying it for $100.00, with $60 to be paid upfront, and the remaining $40 to be paid annually in equal payments?
    • I did say no low balling (Insert copy and paste article from Motor mag with complete history of R32 GTR development and racing history here)
