Hey guys im looking to get a new pump for my active lsd and possibly the diff as well? not quite sure.. but the reason for doing is so is simply because i cannot get power to my pumps hense my diff will not lock up making my active lsd light stay on!
  • 3 weeks later...
the active LSD light stays on when the system fails
only the SLIP light should come on when you "loose" traction or when the computer thinks youve lost traction
A-LSD is a warning light, if its on, the system has failed and given up and wont run the pump or any try to detect traction loss
this usually occurs if the A-LSD computer gets no TPS signal or the wheel sensors are toast
have you done any major changes lately? ECU fiddling? stuffing around with ABS or TPS sensors?
and if you find out its still f**ked DO NOT spend money on the a-lsd system
but a real mech diff or a 1.5 centre from nismo
i wouldnt spend money on a new a-lsd pump etc if you find your pump is toast
imho waste and get a real new centre
