  • Replies 232
I soooooo wish I could come but I still only got my N/A Vl so I would feel a little out of place but hopefully it wont be to long till I'm a proud owner of a R33. So you guys going make sure you take heaps of pics cause this will be an awsome sight to see :cheers: have fun guys... and of course girls :D
Hey guys for all u northside skyliners were meeting at the woolies car park on beams rd at taigum for a 6:15 departure to springwood.
Michael
so how many people are meeting at woolies at taigum for 6:15 departure???
if there are a few i will rock up and cruise down there too...
r32......r33......r34...........am i the only way in a old car
Bro is it a SKYLINE????
YYY EEE SSS !!!
then dont worry about it!!
its all gd!!
ill be chillin with anna/jordan32, my dad in GTR57, and 29LAY
at the carpark!!
around 8:30pm
c ya then!!!
I'll be sending out a PM tonight with final details and meeting points and final destination points.
I have moved the meeting spot due to minor works still being completed on the carpark. It's only 100m down the road at the set of lights and in near Red Rooster. I've got map's and everything that will be included in the PM.
I can't wait! Get washing guys and girls!
I am keen if I get my act together that is only down the road!!!
Are we going Gateway then???
I will contact GTR Cam and see if he wants to do the same also!!!
Sorry Bob, but I will have to pull out..... :D
I "FORGOT" about a wedding that I RSVP'd to a month ago that is on, you guessed it the same night.....
Have fun all
Cam :D
yep, guess this means I will have to wash the road grime and bird poo off the silver whale. Get the batteries in the uniden charged up and dig out the SAU Tshirt.
Short of national disasters I will be there. (frantically touches wood)
    • Hi All, New member here, I've joined to help my son with an issue that is truly doing our heads in. I'll start with a bit of an overview. Chris carried out some modifications to the engine to try and extract just a little extra power out of the motor and make it a bit more efficient. Previous to this work, the car already had an upgraded exhaust, increased boost up to 14psi, modified standard turbo to metal impellers and slightly oversized, upgraded fuel pump, been dyno-tuned at JEM, and some other bits n bobs like coil packs etc. Before the current mods it was making 236rwkw at 14psi but after the new mods it now makes 209rwkw at 14psi. The work he carried out is as follows, timing belt service, water pump replacement, return to sump radium catch can, had oem head rebuilt and machined 0.2mm, fitted Athena cut ring head gasket 1.2mm thick, arp 2000 head studs, added rear prp head drain, added an external wastegate 40mm turbosmart welded off the stock manifold and plumbed back into a 3in dump. The car has been on the dyno and apparently the ignition is working, fuel flow and fuel pressure is fine, injectors are fine, spark plugs are working fine, Maf is working, O2 sensor is working, TPs sensor is working, VCT is working, CAS is working, boost leak test showed no boost leaks, compression test first crank cold 135psi and got to 150psi across all cylinders once cranking, timing is confirmed at tdc with a dial gauge and the cam dots line up, no blockages in intercoolerm throttle body or pre-turbo intake, no blockages in exhaust, cat conveter or down pipe, turbo looks fine and spins and wastegate looks fine and is new. Soz for all the detail but after all this, it has been in 3 times for dyno and each time comes back stating it's not going to make power. After the first (or second, can't remember now) trip to dyno we did find the timing out by one tooth and this improved things, but it is still well down. Does anyone have any ideas?  Any replies much appreciated as we're just not sure of which direction to take this. Regards Rob (Chris's Dad).
    • That's just a gauge, with a certain amount of electronic damping, and no-one cares if it is timely-accurate. I'd hesitate to use it for an ECU MAP input without knowing that it was a nice signal. Responsive but smooth. Not laggy. Not lumpy.
    • Took the dirty BMW to an actual drag meet so I could do a legit full pass on a sticky enough track and had a quiet goal to try and beat my PB in the old R33 GTS25t The time to beat:  R33 on stock RB25, Internal gate GT3076R on stock manifold tuned to about 17psi on BP98 and running on drag tyres: F20 M135i with intake, dump pipe and MHD OTS Stage 1 tune on street tyres - didn't even drop the tyre pressure: Kinda similar, and kinda way different
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
