Massive Skyline Cruise Number II
NismoGirl
 Share
still just a maybe at the moment Erin , will find out in afew days when the line will be ready ! Any more info about the SAU QLD club , will it be starting on that day as well ?
  • Replies 232
I need to buy a UHF radio, im thinking about getting one of the good transciever kind.
So i have a scanner aswell, boostcruising i think it is lists all the different areas police frequencies. Would be pretty cool to be able to see what 'they' are upto for once.
Cheapest one is like $300 tho
put me down as a maybe for the moment as the car may not be legal at that time! but will work on getting it ready in time for this event!!! you just have to promise no one will laugh at my old old skyline!!! :)
just need to check my budget status again (mostly current homeloan) and if all goes well i will have the GTR within 2 wks. I currently have one that i have had my eye on for over a mth now. Getting the car inspected this saturday, so fingers Xed.
PS: R33 :rofl:
just have to add i was at bwcp for the last one and got chills when everyone arrived, nothing better then seeing and hearing a line of skylines down shifting down the hill to turn into the car park, i had the r31 for that night!!
Providing I can get my car down here by then( its STILL in Mackay):P I will be there....although i will break the tradition of the round taillights as i still cant find any for sale in japan
We are actually going to make a detour on the way down to stop for hopefully what might be some really good pics.
Hopefully cyrus wont chase rabbits and we won't be scared out by security.
And the rule still stands, be a wanker, your not welcome. Especially at this point in the cruise.
Guest
 Share
    • Harness update time have had great fun and learnt so much already so far with this project. I started off making both the ignition and injector sub harnesses in the hope any mistakes i made here aren't as hard to undo and learn from as the main harness.  A cool comparison of the old harness using presumably TXL wire and the new which is using Tezel. Also opted to use DTM plugs to keep the whole setup as neat and tidy as possible and tucked the wiring under the coil bracket to try and keep it all from sticking out too much. Although the injector harness, I'm not overly happy with as I'm still using the rubber boots that are supplied with the type of plugs it just looks ugly and sticks out like a sore thumb with the white identifiers so a slight redesign may be done.   Then it was main harness time and most importantly trying to route it nice and away from the heat it will use the OEM heater hose routing which is no longer present to keep the harness up high and secure. it's amazing how much smaller this harness is able to be compared to the old one. plugged everything into the emtron and with the help of the tuner again attempted to start it up and instantly fired up and running smoothly on all 6 which was a big shock to myself. So still some routing and adjusting to be done for the final fit up and installing a knock sensor harness plug which is in the post all has gone surprisingly well.     The old harness for shits and giggles.
    • They do that at random every now and then, with almost no detectable cause. Mine has done it a couple of times (over 25 years!!). Never worked out why.
    • I don't post on here and have been lurking for some time now. Many of the topics have helped me out more times than i can count. I was racing yesterday (11/9) and blew a front right CV shaft. I have spares so I popped a new one in. A thread i read previously said to check the engine mounts if you blow a front CV. Upon inspection, the front right mount was completely separated from the upper plate. This discovery saved me time and money, because i would have blown another CV if i went back out. Just wanted to thank you guys and wish everyone luck with with their builds. (Now if we could only come up with a solution for my power steering belt flying off after hitting the rev limiter, lol)
    • Either way he still need those style of spacer to go into the manifold because the photo he currently has is not going to work
    • You can just get the injector bosses, which allows top feeds to fit. He can use the same injectors without issue, like these (another option): https://rocketindustries.com.au/af59-2210-rb25-fuel-injector-inserts     The Racework ones look a bit better: https://www.nzefi.com/product/raceworks-lower-injector-mounting-boss-kit-for-r33-rb25det-s14-s15-sr20det/   You could also just get a similar kit like the Radium one by Plazmaman: https://plazmaman.com/product/nissan-rb25det-r33-billet-fuel-rail/?srsltid=AfmBOoogfYq49X0fu2Wdbf8yOf6zt9egyPAif_gn3Qr3G8hzAphhTgOkO70
