  • Replies 232
I soooooo wish I could come but I still only got my N/A Vl so I would feel a little out of place but hopefully it wont be to long till I'm a proud owner of a R33. So you guys going make sure you take heaps of pics cause this will be an awsome sight to see :cheers: have fun guys... and of course girls :D
Hey guys for all u northside skyliners were meeting at the woolies car park on beams rd at taigum for a 6:15 departure to springwood.
Michael
so how many people are meeting at woolies at taigum for 6:15 departure???
if there are a few i will rock up and cruise down there too...
r32......r33......r34...........am i the only way in a old car
Bro is it a SKYLINE????
YYY EEE SSS !!!
then dont worry about it!!
its all gd!!
ill be chillin with anna/jordan32, my dad in GTR57, and 29LAY
at the carpark!!
around 8:30pm
c ya then!!!
I'll be sending out a PM tonight with final details and meeting points and final destination points.
I have moved the meeting spot due to minor works still being completed on the carpark. It's only 100m down the road at the set of lights and in near Red Rooster. I've got map's and everything that will be included in the PM.
I can't wait! Get washing guys and girls!
I am keen if I get my act together that is only down the road!!!
Are we going Gateway then???
I will contact GTR Cam and see if he wants to do the same also!!!
Sorry Bob, but I will have to pull out..... :D
I "FORGOT" about a wedding that I RSVP'd to a month ago that is on, you guessed it the same night.....
Have fun all
Cam :D
yep, guess this means I will have to wash the road grime and bird poo off the silver whale. Get the batteries in the uniden charged up and dig out the SAU Tshirt.
Short of national disasters I will be there. (frantically touches wood)
Guest
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
