S2000/Integra Type R are both faster than a Magna and still legal under P plate laws.
Also 4x the price
yeh forgot to mention that my original post was for cars basically under 10K becasue thats the max i was going to spend so i didnt consider $30,000 s2000's or 15K> DC2 R's
also Supra's are quick, my main point was that for the price sports sedans and the best option performance wise
or you could buy a small import (MX5, MR2, VTEC Civic/Integra) and make it handle like Krazy.
  • Replies 165
'93 stock NA Supra will do 0-100 anywhere between 6.2 (independently tested) and 6.7secs (factory claimed) according to various sources. nyaanyaa.gif
the gear ratios of magnas require you to shift into 3rd before 100kmh, so give a slower time. same sort of thing goes for cars that do sub 4 second 0-100s will all do it in 1st gear. the moment you have to change to second you get much slower times.
Err quoted kurb weight of an s15 is around 1400kgs with an alloy sr20 add 120odd kg of iron rb and they would weigh around the same as an r34
Thats like when people put rb20s into s13
um it weighs slightly more than a r32 with the same motor
Ditto for the Supra. Pretty sure it will only get to ~90km in second. I wasn't really being serious, I was trolling. IMO, I like Magnas as much as I like Falcodores. They're great for what they're designed to do, but anyone who acts like their some sort of performance machine should be shot. Not saying NA Supras are anything special, every car in this thread is woefully slow, but I'd still argue Supras are the best value P plate legal car you can buy.
and how much does yours do?
Dunno. Perfect launch and shifts I'd hope it would be under 6.5seconds, as it has decent tyres, LSD, and a full exhaust, but then again it is a 17 year old engine.
that's the reason i bought a vt commodore for the 60+km drive to work everyday. cost me $3550, even being lowered with 18's it still gives a reasonably soft and smooth ride (although i'm going to get some stock springs for it since it will be much cheaper than a camber kit), uses less than 9L/100kms and has very comfy seats and cruise control.
That's fine. What annoys me is that every single P plate Magna I come across tries to race me. As if they have to prove their car is the fastest P plate legal car and the Supra is a challenge.
lol marc's onto something there...
I had a na 33 gts4 manual for a daily, got around 10-11l/100km but got sick of the noise and harsh ride (that said, my 32 is absolutely rock solid)
Sold it and bought my au falcon for 2500 (158km), spent a grand and a half on it making it pretty / new brake pads / exhaust etc and its running brilliant. Gets me 12l/100km around town without needing a light right foot.
Loads faster than the na33 too.
No RB in silvia then lol, i gave thought to it but never bothered reseaching whether it will work ,engine conversions dont seem like fun at all, anyway good idea or not weight is the NA's number one killer.
Edited by starwarz
This thread got me thinking what my car would do 0-100, had a crack at it last night got around a 7.3 second time.
Will kick out the 100kg passanger next time and see what i can get, goes alright for my needs.
haha lol n/a skylines were really not built for being pushed that hard tbh, so scared that the clutch will go any minute..
Yea... destroyed the stock clutch half way down the drag strip... now have a heavy duty Exedy + all of the N/A running gear is the same as a turbo'd car only difference in mine is that it has a 20 box instead of a 25.
Try getting that sort of time uphill..
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
