Hi :action-smiley-069: I'm Timothy but call me Tim or Timi.
I own an R33 with a RB25DET in a GTS shell :ninja: and have owned it personally for almost 3 months
It was a great find for me since its registered as n/a n im still a kid on L plates people just assume its not turbo because of the 4 stub hubs/wheels so its all good.
The Skyline is still a work in progress but has had a little done to it like: exedy button clutch, forged JUN pistons, Z32 afm, APEX-i power intake pod filter, larger radiator, Blitz LM fmic, Blitz dual solenoid boost controller, Nistune piggyback chip, decat exhaust, adjustable coilovers (not 100% sure on brand, previous owner said KONI but i think there only for GTR?), screamer pipe, GReddy RS dump valve (to be fitted; need adaptor), cold air intake, APEX-i sway bars and strut bars, removed HICAS, Nismo lsd.
Heaps of cosmetics too but not really intro-worthy :D
I'd like to do heaps more to it like ecu remapping, BEE*R rev limiter, 3.5inch exhaust with twin cannons, SARD 1000cc injectors, twin bosch 044 fuel pumps, garrett t04z bb tu rbo mounted on 6 stem turbo pipe (exhaust manifold), GReddy intake manfold, GReddy top feed fuel rail, Tomei poncams etc.:turned: Not in hurry though, just want it to be completed before my P's (18yo)
Not hard to notice my car round Victoria because its has 17" Advanti Medusas on her (ew..should be on a Camry :down: but i wana spend money on performance stuff first) and Nismo "Graphics" on the doors :wacko:
But like I said: its still a work in progress :cool:
:thanks: TY for reading n i hope to learn more on sau
Tim.
BTW! how do you get those litte pics of your car under your comments/posts? eg: VSPECT has little grey R33 GTR like his under his posts :banana: and GTS-T_Sedan has little gold EVO 7..there mad as!!! :worship:
https://www.sau.com.au/forums/topic/362566-my-sau-n00b-intro-from-vic/
Welcome Tim!
You certainly have more than a few bit's and piece's done to your car.
May i say, please don't forget at some point to put bigger brakes on it... this may mean a 5 stud conversion however.
Welcome again,
Shannon
Welcome... It's great to have grand plans...
However perhaps don't go out and build a 440rwkw / $35,000+ build right away, especially not with a N/A shell at least anyway.
I kid you not when I say it will kill you :)
Also to note, 3 points as soon as the Police pop the bonnet, something to be mindful of given it's turbo (and yes, the Police most certainly can tell just by looking at it).
Big thanks for the warm welcome so far :cheers:
I didn't want my intro to be an massive drain, just to keep it user friendly I just wrote the power wise upgrades I'd like to do :D
Bigger brakes are a must and so is a cage and other reinforcements since its going to be seeing laps and 1/4 miles (But not till I have heaps more driving expierience :laugh:) Also seats (incl. harnesses) are a required too. Already has strut/stabilizer/sway bars. Going to also do basic weight reductions and replace things with carbon fibre too.
Although I'm on my L's its not used and will never be used as a daily or in wet weather, its purely a weekender because during the week I got my mum's vx commo :teehee: lol petrol isnt cheap so commo is on gas. Once im on P's my dad will nurture the Skyline and I'll drive his Merc as well as Ninja 250 :ninja:
BTW power wise, aiming for figures around 280-300rwkw. Anything over is bonus but keeping it under 320rwkw. Shes runnin 14psi atm but want to replace turbo first (Shattering ceremic turbo blades sound really frightening :unsure: )
The build is going to last over a period of 18-24 months so there is plenty of time for learning as well as progression.
Exteriorly the car looks pretty basic apart from graphics lol, but as R31Nismoid said, its obvious is a turbo under the bonnet + massive fmic literally gives it away but side on eg: at traffic lights, all you see are 4 stud rims and blue "GT" emblem on side but it flutters/"Doses" like a mofo which also kinda gives it away :wacko:
Thnx heaps,
Tim
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
