hey, i got a problem with my rb20det when you are about to come on full boost it starts missing and not running right, and from a stand still when u put the foot down it dose the same thing, starts missing, but if u ease the power on gently and stay under 3k it is happy and runs fine??? can anyone help
https://www.sau.com.au/forums/topic/362597-rb20det-missing-on-boost-help/
In terms of checking them, somewhere dark/nighttime is best and you would normally see them arc out on to the engine....
Other than that do you run std boost? Checked/changed plugs recently?
also its really hard to start, like it takes 10 goes to get it running and when it fires it splutters for couple seconds then runs idles fine?
Edited by andyyyyyyyyyyyyyyyyy
check the spark plugs as well. pull them out, look at the colouring as well as get a feeler gauge to measure the gap. also inspect the coils for any signs or melting, etc (that's a sign they are arcing out). if they all seem fine then the issue may be fuel related and it might be worth putting the car on a dyno to get them to check the AFR's.
i put new plugs in today didnt change anything and coil packs look fine and i looked at them at night time and i didnt see anything arcing out.....
Just thought, maybe you have the ignitor separate from the coils??? If yes that could be faulty.....
yeah the rb20 has a seperate ignitor and they do cause problems that are the same symptoms as dodgy coils. one major advantage is that if you have a mate with a rb20 or s1 rb25 then you can swap them over to try in just a few mins (much easier than swapping coils)
true, i just need a mate with a rb20 :D, so u also think it would be the coil packs that is making it not want to start straight away when its cold? takes a couple of gose to get it to fire up
yer fix it completely now i cleaned my AFM and it was covered in oil......
if that helped then it means that your coils are stuffed. new coils should make it a lot better.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
