hey, i got a problem with my rb20det when you are about to come on full boost it starts missing and not running right, and from a stand still when u put the foot down it dose the same thing, starts missing, but if u ease the power on gently and stay under 3k it is happy and runs fine??? can anyone help
https://www.sau.com.au/forums/topic/362597-rb20det-missing-on-boost-help/
In terms of checking them, somewhere dark/nighttime is best and you would normally see them arc out on to the engine....
Other than that do you run std boost? Checked/changed plugs recently?
also its really hard to start, like it takes 10 goes to get it running and when it fires it splutters for couple seconds then runs idles fine?
Edited by andyyyyyyyyyyyyyyyyy
check the spark plugs as well. pull them out, look at the colouring as well as get a feeler gauge to measure the gap. also inspect the coils for any signs or melting, etc (that's a sign they are arcing out). if they all seem fine then the issue may be fuel related and it might be worth putting the car on a dyno to get them to check the AFR's.
i put new plugs in today didnt change anything and coil packs look fine and i looked at them at night time and i didnt see anything arcing out.....
Just thought, maybe you have the ignitor separate from the coils??? If yes that could be faulty.....
yeah the rb20 has a seperate ignitor and they do cause problems that are the same symptoms as dodgy coils. one major advantage is that if you have a mate with a rb20 or s1 rb25 then you can swap them over to try in just a few mins (much easier than swapping coils)
true, i just need a mate with a rb20 :D, so u also think it would be the coil packs that is making it not want to start straight away when its cold? takes a couple of gose to get it to fire up
yer fix it completely now i cleaned my AFM and it was covered in oil......
if that helped then it means that your coils are stuffed. new coils should make it a lot better.
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
