I'd just like to clarify before I go ahead and plumb everything up. Please let me know if you see a problem with this:
Step 1:
Take this hose
and connect it to this side of the TB
Step 2:
connect this side of the TB and T it to the other line in yellow (read from bottom up)
Any advice would be appreciated,
Thanks!
Do you live in a city where your throttle body is likely to freeze up?
I havent run coolant lines on my throttle body since I put my Greddy copy on. No problems at all.
Its only there to prevent the butterfly from freezing up under cold conditions. Someone might be able to give you a temperature at which this might happen but I figure if the ambient temperature is above freezing then theres no real way the air can get colder from going through the system to cause the throttle body to freeze
I live in the northern suburbs of Adelaide. I drive to the gym at 5am almost every week day, so in winter it could be as low as 0掳C I guess :unsure:
hmmmm... Well I'm not gonna tell you not to connect it then. It may very well be fine but in the off chance its not I'm not gonna be the one responsible for the advice lol....
I live in North Queensland so it never drops below 6 degrees and it rarely drops to that anyway lol so not a problem here.....
