All items from an R32 GT-R. Cash only, no swaps.
RB26 Head with stock cams. $1200
RB26 Covers, Cam Covers/Coil Pack Cover and Timing Belt Cover, plus -10 Breather fittings. $400
RB26 Timing Belt Cover (Spare). $100
RB26 Inlet Manifold & Throttles (pulled apart currently). $250
RB26 Stock Turbos/Exhaust Manifolds/Dumps. $450
RB26 Injectors/Rail + Resistor Pack. $400
RB26 Harmonic Balancer. $100
RB26 Alternator. $80
RB26 Starter Motor. $80
RB26 Power Steering Pump. $80
RB26 Pistons/Rods. $180
RB26 Engine Loom/Mines ECU + AFM's. $400
Also available RB30e complete with Auto, ECU.
Please pm or call me for more information. Scott 0 418 57 9423
https://www.sau.com.au/forums/topic/362609-fs-rb26-head-and-other-engine-parts/
    • Interesting. Some of them were tight to lol
    • That's right, simple but works. Run out of load? Rescale the table lol. Want to be lazy and not rescale? Drag the K
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
