Hey guys.
Just looking for some advice for a day at the drags coming up shortly in regards to getting the most out of my car without changing any major parts or spending huge wads of nonexistant cash.
R33 Gts-t, with 245rwkw running slightly unsuitable Tein Superstreet coilovers. I am not changing the suspension so I want to make the most of what I have in terms of Aerodynamics and weight savings.
I have already removed the backseat, spare tyre, tools, sound deadening, rear wiper.
Running 15" steelies rear with Mickey Thompson ET's are set to 20psi and stock 16s at the front set to 45psi (max pressure rating on the Tyre wall). Also will be using tape to block any unneeded gaps on the front to assist airflow.
I run a GTR wing day to day. Any opinions on this whether to remove it to reduce drag and weight??? Or leave it to try and keep some weight over the rear wheels???
I've done a couple of drag days before but am certainly still a rookie at it. Any other suggestions I could trial to try and sneak a few 10ths?? Looking for anything under 12.5 but I don't think I will be able to sneak 11's with the Tein suspension. That won't stop me trying. Prev best was a 13.8 a couple of years ago but with near standard car on the same MT tyres.
Surely theres more I can do without spending cash to help make it quicker
Cheers. Luke
https://www.sau.com.au/forums/topic/362633-drag-preparation/
No point taping up panel gaps etc, you wont be going fast enough to have to worry about that
But yeah, you will need to find the best way to launch I used 4500rpm and rode the clutch to stop wheel spin (before I got a 2-step)
Everyone has a different way of doing it, you will just need to find what works for you
Man DW about the coilovers. With rock hard Jap-spec stuff i was running 12.9 with 220rwkw in my GTSR, full weight and over 1500kg. (seats in, spare etc).
Also airflow - forget it. It's not fast enough as stated.
1.9-2.0 60fts consistently back in the day. That was in 225 Dunlop 3000A street tyres :D
The launch is where it all counts. The rest is not as important at all as it's just ensuring you shift correctly.
Check the tyre pressures after your run as well and adjust to suit if need be. I'd expect you to have 1.6 60ft's without much drama at all.
With 245rwkw on MT's you would be in the high 11s / deep 12 if you can get the launch right, I think you'll need more than 4500rpm given the tyre choice off the line.
I might come along that day actually as myself and all my mates wanna do a drag day :D
Cheers for the advice guys.
Sunday 29th May at Heathcote is when i'll be out there. Be great to have a few others there. Esp people with a lot more experience then myself. Of all my friends my closest competition will be a standard BA XR8 Falcon on her first attempt. So im only really in it to see low I can get my times. Anything over 12.5 I will be leaving the Skyline parked outside and the Statesman will be moving into the shed.
Cheers. Luke
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
