I am looking to purcahse another skyline after selling the WRX. I went and had a look at one that i am interested in buying. The build plate says 1997 and everything suggests that except for the airbags. It has a single (95 style) airbag and no passenger airbag.
My initial thought was that it has been in an accident and airbags have gone off and then replaced dash but i can not find any signs of damage what so ever. I don't understand how this could be a possibility, 97 was the second year of the series two and surely would not have come out with a single airbag.
Can anyone shed some light on the this?
Cheers
https://www.sau.com.au/forums/topic/36270-si-skyline-dual-airbags-option/
The thing is that every thing else about it is series two, bonnet, front bar, grill, rear skyline label is colour coded, seats, speedo and surrondings, dash... Only thing that isn't is the airbags.
It is also in very good condition. Have seen cars before that have been in accidents so i know some of the things to look out for and it looks good.
blx - when you say 95 style airbag... does that mean it has the 95 style wheel... like this : http://www.skylinesaustralia.com/forums/at...achmentid=11876
If so, then I would suspect that its a bit dodgy. I am pretty sure I have read that airbags were always options in skylines (but most had them anyway)... so if its the right wheel (S2, not s1 like above) and no passenger airbag, then i wouldnt be worried.... if it has the S1 wheel, then i would be a bit suss tho.
maybe just its interior was previously damaged, so they had to replace the dash and mix n matched..
or perhaps it previously put out 600hp, and had 12 guages across the dash, leaving holes, which they couldnt hide, so they replaced the dash :rofl:
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
