+1 nascar would be way more interesting to watch on aussie tracks than the sequential cheatbox taxis.
the less modern technology the better, leaving more margin for driver error and the resulting overtaking.
bigger, heavier, carb'd 4 speed manually shifted tanks. awwyea
i know its a free world but are you for real? nascar has to be one of the most boring motorsports.
my point was that the V8s move closer to Nascar rules every year and thats why they are getting worse and worse.
im not trying to have a go or start somthing just making sure that my point earlier was taken sarcasticly.
There was a write up in todays paper about it.
Towards the end of the write up he mentions he was disappointed with the fire guys as when they came and approached the car none of them squirted him with water.
I noticed that as well. The poor guy obviously had hot hands, he was shaking them like F*CK!
It was hot hot hot!!
Face suffered burns I guessing from him having his helmet visor up?
Burns are never fun, looks like bad sun burn on his forehead.
Edited by Whiplash
Wake up call for me.
I'm going to make sure I wear my balaclava from now on. Every bit helps hey!
All V8 drivers have to wear them, after the issue at Bathurst the other year when Ambrose was 'dobbed in' for not wasn't wearing one.
yeah good call on the balaclava...it is optional for racing (not national) but required at rallies.
also interesting his hand were burned, I'm sure he had compliant gloves on. I wonder if gloves should haev more than 1 layer.
good to see he is OK, I guess the operation is to put skin from his bum onto his hands?
I realise they have to wear them, was referring more to myself.
I'm only running in supersprints so it's not mandatory to wear a balaclava or even gloves. I have a balaclava and I often don't wear it. Sometimes can't be bothered or don't want to be too hot wearing it. I'm going to make sure I wear it everytime from now on.
Early days I was never a fan of wearing gloves either. Then I figured it would be hard to undo seatbelts, window net and open doors while your hands are on fire. Gloves buy you some time to get out.
It's easy to forget some of the dangers of motorsport and become complacent.
This happens in many categories, I think drivers need to have a button on the steering wheel that will set off an alarm in the starters tower and trackside led lights if they stall on the grid.
As it happened live I thought wtf is that board the starter is holding out, the 5 second board? but the lights are green, then it was just a fireball, so the marshalls were all onto it but the drivers have tunnel vision at that point in time.
What about a transmitter which recognizes if a car is stalled and sends a warning off to the guard tower.
You could even wire safety cut-off systems so all cars have their engines cut when something like this happens.
Then again.. this is just attacking a problem directly as opposed to finding a safer way to starts.
Not keen on rolling starts... launches are awesome to watch
Edited by SKITTLES
Jake jone a SA drift driver was recently driving a borrowed car at a drift event in New Zealand. some how a fuel line split and it had an in cabin fire. in the time it took to stop the car from 120+ he recived burns to his neck. he had a helment and race suit but no balaclava. i bet he wishes he was wairing one.
They wave flags when a car stalls on the grid. Problem with that, is that the driver is so busy that they are unlikely to see them being waved. Same issue would apply to a light in the cockpit.
There was an accident at nightmasters at the beginning of the year, that was pretty much the exact same circumstances. Though not quite as dramatic (no fireball).
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
