Selling a pair of genuine R33 GTR Series 3 projector type xenon headlights removed from a 97 Series 3 R33 GTR.
Both headlights are complete with ballast, globes and wiring. Driver’s side light has the usual fading which can be seen in the pictures and is also missing one of the rear covers (does not affect operation). Passenger side light is in good condition. All mounts and tabs are intact. Nissan want over $3500 for a pair of these brand new.
post-69561-0-93147700-1304230421_thumb.jpgpost-69561-0-53985500-1304230415_thumb.jpgpost-69561-0-74215000-1304230826_thumb.jpgpost-69561-0-49595100-1304230425_thumb.jpg
Asking $1000 for the pair
OR
Willing to separate – Passenger: $800 Driver: $400
Also for sale is a passenger side headlight from a R33 Series 2 GTST. Has damage however has been repaired. The lens is nice and clear. Comes complete with globes and wiring.
Asking $60
All items are located in Adelaide, South Australia. Willing to post Australia wide at buyers expense. PM for any enquires.
What damage did the gtst light have?
The GTST headlight has several cracks on the housing which have been repaired with glue and silicone. Also the top mounting tab has been repaired.
Just curious, is there a difference in the GTR xenon headlights and the Ser II GTS headlights would be interested later down the trak to get a set if they are the same
As far as I know, the series 3 GTR Xenon’s will not fit into a series 2 GTST easily due to the different shape of the series 2 bonnet, reo bar and grill (and perhaps other parts). I’ve heard it’s possible to make them fit but it’s a lot of work. Apparently they will fit into a series 1 GTST but I believe some modifications are still required. Check out this thread as there is a discussion about this.
R33 GTR Series 3 Xenon Headlights (pair) – SOLD
R33 S2 GTST passenger headlight still available.
  • 3 weeks later...
    • My crystal ball says that when they replaced the pads, they didn't replace all of the brake hardware (could be a missing shim, pin, spring, etc).  Finding a low dust pad should be very easy. Have a google for things like, low dust / soft pad compound / easy on rotors. Your dust primarily comes from the rotors getting eaten up by the pads.
    • I think old mate is going to continue to hold out for awhile at that price
    • OBD1 is a catch-all term for pre-OBD2 which could have basically any connector design and protocol. I really don't understand this attitude against using data logging for issues that can be multi-causal and subtle. A no-start situation or something like that sure the scan tool does nothing but if it runs like shit it can often be a sensor issue. When a friend of mine reliably had issues with his N54 not able to stay running eventually I narrowed down the issue to a faulty fuel pressure sensor. Only way I could do that was a scan tool to look at the fuel rail pressure and see shadow codes for fuel pressure. Then check against a pressure gauge. Is reflexively firing up the data logger probably a bad habit? I guess, it can encourage people to not listen/observe but on these old OBD1 cars just taking a log really doesn't do anything by itself. You still have to synthesize everything you know and think about what it all means.
    • https://www.carsales.com.au/cars/details/1999-nissan-skyline-gt-r-v-spec-bnr34-manual-4wd/OAG-AD-24005316   i reckon some former Skyline owners are wishing they held out a little longer before selling up?
    • Yeah saw that video on YouTube. But he got a R grade (repaired) high mileage model and proudly advertised the fact it was super cheap and no doubt with issues. I wouldn't be going the cheap and nasty route.
