i need to d my timing belt on my rb25det which is in a vl i have read some of the guides on here and they seem pretty straight forward however im a little sceptical baout the timing side of things when it comes to the CAS due to i dont have a timing light. does anyone here in WA know how to do a timing belt that could help me
https://www.sau.com.au/forums/topic/362714-timing/
also is it worth buying a whole timing belt kit if the tensioners are not stuffed. like they say only fix whats broken. its just im on a tight budget at the moment i know its the life of my engine and i shouldnt neglect it
You just answered your own question. Buy the whole kit IMO.
https://www.sau.com.au/forums/topic/362714-timing/#findComment-5788653
depends on their condition. i've re used myne twice now, but i know for a fact they're still less than 20k kms old
as for the cas, if you mark it properly (dont use a fat texta) and align it perfectly when you bolt it back up it'll be so close it wont matter. i usually scratch marks into it with a very small flathead screwdriver or similar
https://www.sau.com.au/forums/topic/362714-timing/#findComment-5789031
If there is any, and I mean ANY "rumbling" noise when you spin the pulley, thn replace it. The bearings arent serviceable, so there is no way to lube them at all, and the rumbling will indicate balls touching (nohomo) the race which means they are already on their way out. Having seen a couple of RB's after one of those bearings lets go, its not a risk I would be willing to take, myself.
As for the timing - like johnno said, use a scratch (or mark it with a texta, then scratch inside the texta mark so you can see it) and you will be fine - but if you do get your hands on a timing light, make sure you put the ecu into "adjust timing" mode before trying to adjust it. Seems like a n00b mistake but you would be suprised how many people miss it.
https://www.sau.com.au/forums/topic/362714-timing/#findComment-5790137
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
