Hey guys,
Well after watching another guys video on engine noises, and from my original suspicion, the noise my car makes is a tensioner/bearing noise from the cam cover. Thus I need my belt, tensioners and bearings changed. Who here in Sydney can do it and how much do you want? Please PM me.
I can get the kit or if you can provide it and give me a total cost on parts plus labour + days the car will be out of action will be greatly appreciated.
Cheers guys.
Edit: Yes I have searched but no one ever seems to put a price they paid on anything. Thats what I'm after, what people actually payed not what someone told them on the phone.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/362723-who-here-can-do-timing-belts/
I'm actually looking forward to doing this for the first time (whenever that will be). But it SHOULD be just a day job. I got quoted $500 from a place that wasn't really a skyline centered place once. Probably would have ended up as more though. Maybe call around the recommended (in the nsw section, have a search) performance mechanics in syd and get some quotes. Might cost a little more but at least they'll know what they're doing.
I don't have most of the tools(pullers, cam locker, timing light). Its also looks like a PITA to work in such a tight spot, even though I changed my clutch my self under my car haha.
Damnit now I'm considering it haha.
Galois, is that $500 including parts and labor?
Edited by SargeRX8
http://meetdallasberry.com/files/GuideChanging-the-Timing-Belt-on-a-RB25DET-4.pdf
I think I'm gonna give this a go lol. Actually looks and reads alot easier than changing a clutch. Before I pull the old belt n shit off I'll ensure all the markings are in place so it can be ligned up properly. And any old pully puller will do!
Edited by SargeRX8
http://meetdallasber...a-RB25DET-4.pdf
Yes I too get the impression this is an important step haha
It's actually THE MOST IMPORTANT step. Get it slightly wrong, and the car will run a bit rough, but get it seriously wrong and it can do major damage. Srsly. :D
I don't think the RB engines are an "interference" engine - someone can correct me on that - but some engines (like those in the later Holden Astras) are, and if a timing belt breaks, it's goodbye valves and pistons, and hello big repair bills and empty wallets.
Parts:
http://www.kudosmotorsports.com/catalog/nissan-100000km-service-kit-water-pump-timing-belt-nissan-skyline-r33-gts25t-rb25det-p-558.html
$434 just the parts; and I'd assume roughly $600 for labour (takes a few hours to do, even rushing it). Don't expect too much change for $1k for the full job.
I've got the RB25 manual, and it has step by step instructions on doing it.. i just suck and can't follow them :P
i got mine done at boost tech in fivedock for $690 for all parts and labour, new waer pump aswell
i'm friends with the owner but i rang up and got the quote beofre telling him who i was
so if you call them i'm sure you can have it done for under $700
you can look it up under "elite autos" in fivedock the owners name is Tony
Yeah they are an interference motor
Just to clarify, but you probably knew this, I was being sarcastic. What would you do if you managed to stuff that step? I remember reading about someone on here who'd done it and was rather lost.
    • Is there a diameter difference in the stock to Nismo? If so, the weight alone won't be indicative when comparing flywheels of the same diameter, since the radius of the flywheel acts on the moment of inertia with a square factor, where as mass is linear. Roughly going from a 4.5kg flywheel with radius 20cm, to a 9kg flywheel with radius 14cm would see them act the same. This calc is just here to act as a brief numbers comparison and reflects no actual RB flywheel diameters etc. it also assumes even weight distribution (thickness) throughout.
    • It seems this could be due to a restructure/team direction change... Or... You're working with a different category of vehicle... Or you've decided you'd rather be able to play with your own cars again...   I'm hoping the latter...
    • had 4 weeks off over xmas and well did some stuff to the shed and BRZ, well short of is I don't work full time in supercars anymore as of yesterday.........
    • Did you get any down time over Christmas, or have you had any since to play with this? Or have you given up and are trying to get yourself a second hand V8SC instead?
    • A random thought I had just before I hit "Submit on this post". If brake fluid, in a container in my garage that has never been opened goes bad after 18 months, why can I leave it in my car for 24 months in an "unsealed container"... Secondly, some other digging, and brake fluid manufacturers seem to be saying 5 year shelf life... Me thinks there line on 18 months for an unsealed bottle is pretty much horse shit marketing spin. Kind of like how if you drive a car and don't run a turbo timer your turbo and motor will die horribly...   Where I started on this though... Someone (me) started down a bit of a rabbit hole, I don't quite have the proper equipment to do Equilibrium Reflux boiling per the proper test standards. I did a little digging on YouTube, and this was the first video I found on someone attempting to "just boil it". This video isn't overly scientific, as we don't have a known reference for his test either. Inaccuracy in his equipment could have him reaching the 460 to 470f boiling point range in reality. In the video, using a laser temp gun, he claims his Dot3 that's been open in his florida garage for over a year gets to about 420 to 430 fahrenheit (215 to 221c) Doing some googling, I located an MSDS for that specific oil, and from new, it claims a dry boiling point of 460 to 470f. Unfortunately they don't list a wet boiling point for us to see how far it degraded toward its "wet" point. While watching it I was thinking "I wonder what the flash point is..." turns out its only 480f for that specific brake fluid....   As for testing the oil's resistance, I might not be able to accurately do that unfortunately. Resistance level will be quite a LOT higher than my system can read I suspect based on some research. However, I might be able to do it by measuring the current when I apply a specific voltage. I won't have an actual water % value, but I'll have some values I can compare between the multitude of fluids. I'll run some vague calculations later and see if I should be able to read any reliable amount of current. These calcs will be based on some values I've found for other oils, and see how close I'll need my terminals together. From memory I can get down to 1pA accuracy on the DMM. I don't think my IOT Power Tester has any better resolution.
