Hey guys,
Well after watching another guys video on engine noises, and from my original suspicion, the noise my car makes is a tensioner/bearing noise from the cam cover. Thus I need my belt, tensioners and bearings changed. Who here in Sydney can do it and how much do you want? Please PM me.
I can get the kit or if you can provide it and give me a total cost on parts plus labour + days the car will be out of action will be greatly appreciated.
Cheers guys.
Edit: Yes I have searched but no one ever seems to put a price they paid on anything. Thats what I'm after, what people actually payed not what someone told them on the phone.
Edited by SargeRX8
https://www.sau.com.au/forums/topic/362723-who-here-can-do-timing-belts/
I'm actually looking forward to doing this for the first time (whenever that will be). But it SHOULD be just a day job. I got quoted $500 from a place that wasn't really a skyline centered place once. Probably would have ended up as more though. Maybe call around the recommended (in the nsw section, have a search) performance mechanics in syd and get some quotes. Might cost a little more but at least they'll know what they're doing.
I don't have most of the tools(pullers, cam locker, timing light). Its also looks like a PITA to work in such a tight spot, even though I changed my clutch my self under my car haha.
Damnit now I'm considering it haha.
Galois, is that $500 including parts and labor?
Edited by SargeRX8
http://meetdallasberry.com/files/GuideChanging-the-Timing-Belt-on-a-RB25DET-4.pdf
I think I'm gonna give this a go lol. Actually looks and reads alot easier than changing a clutch. Before I pull the old belt n shit off I'll ensure all the markings are in place so it can be ligned up properly. And any old pully puller will do!
Edited by SargeRX8
http://meetdallasber...a-RB25DET-4.pdf
Yes I too get the impression this is an important step haha
It's actually THE MOST IMPORTANT step. Get it slightly wrong, and the car will run a bit rough, but get it seriously wrong and it can do major damage. Srsly. :D
I don't think the RB engines are an "interference" engine - someone can correct me on that - but some engines (like those in the later Holden Astras) are, and if a timing belt breaks, it's goodbye valves and pistons, and hello big repair bills and empty wallets.
Parts:
http://www.kudosmotorsports.com/catalog/nissan-100000km-service-kit-water-pump-timing-belt-nissan-skyline-r33-gts25t-rb25det-p-558.html
$434 just the parts; and I'd assume roughly $600 for labour (takes a few hours to do, even rushing it). Don't expect too much change for $1k for the full job.
I've got the RB25 manual, and it has step by step instructions on doing it.. i just suck and can't follow them :P
i got mine done at boost tech in fivedock for $690 for all parts and labour, new waer pump aswell
i'm friends with the owner but i rang up and got the quote beofre telling him who i was
so if you call them i'm sure you can have it done for under $700
you can look it up under "elite autos" in fivedock the owners name is Tony
Yeah they are an interference motor
Just to clarify, but you probably knew this, I was being sarcastic. What would you do if you managed to stuff that step? I remember reading about someone on here who'd done it and was rather lost.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
