Hey guys,
A friend and I installed a Turbosmart Manual Boost Controller plus aftermarket boost gauge today on my R34 GTT Neo, and we've hit a bit of a problem and I'm not sure we've connected it right.
So far I've installed the controller between the wastegate and intercooler hoses, and I currently have the lower solenoid hose blocked off. The top solenoid hose I've keep connected.
At the moment it won't boost past approx 5 psi and with the controller wound to maximum boost it gets to 5-6psi and then (I think) the ECU chucks the sh!ts and applies a fuel cut.
Is there a problem with the way I have connected everything? Many thanks in advance.
https://www.sau.com.au/forums/topic/362727-boost-cut-at-~5psi-r34-gtt/
I've uploaded a couple of pics to show what I've done.
First pic is the MBC setup:
Also I noticed when installing the boost gauge, that one of the hoses wasn't even connected to the following valve in the pic, forget what it's called, VSV valve or something? Anyway it was never connected and I've only just noticed since purchasing the car. I can't reconnect it without getting a new one so I just clamped the hose. Wondering if this would cause any issues. See pic:
are you sure the guage is in PSI?
it might be mmhg or hg or kgcm2
from memory the stock ER34 has a manifold boost sensor and it trips out around 12psi
it definetly would trip out at 5/6psi as the stock boost on ER34 would be around 10psi (give or take)
The stock gauge is in Kgcm2 and my aftermarket one is psi.
I'm now pretty certain the aftermarket gauge isn't working properly. It may have something to do with broken valve highligted in picture #2 - thats in a similar area where I am feeding the vacuum tube to the aftermarket gauge. I think I may need a new one of those valves.
The boost controller does work now though. I got the solenoid hoses mixed up - need to block the top one and remove the bottom completely. I can set the boost using the stock gauge which isn't entirely accurate however it's set at around 0.75 kgcm2 which is not too high.
I also snapped the plastic bit off that valve. It just runs under the crossover pipe to the carbon canister. I beleive that the solenoid flushed out the carbon canister of something... Just block it off so there's no vac leaks :)
Hey guys,
Are you sure? because looking at the factory maps they run the same sort of TP Load limit (afm cut) as the earlier models but the values seem to have a little more meat in them.
yeah it would have AFM cut and boost map sensor cut
but it wouldnt cut at 5 or 6psi, that would be silly
the std actuator would be 7psi at a stab in the dark
anyone with stock ER34 can confirm stock ER34 boost ?
7psi full boost.
ER34 isn't 7psi. The R34 runs more boost than an R33 which runs 7.5psi and the stock tables don't run into R&R until at least 9psi. If the stock gauge is reading 0.75 kg/cm^2 then that is a touch over 10psi. This is likely the start of R&R - which from what I read is more aggressive than the R33 R&R.
You may also like to note that the stock gauge is mainly inaccurate in that it tends to read LOWER at higher boost than reality. ie. as boost rises it under reports so 0.75kg/cm^2 can be approaching to 1.0kg/cm^2 (14psi)!
You could check the stock pressure by removing the bleed valve and testing again (also confirms you have removed the 2-step boost properly). The compare to readings after reinstalling the bleed valve. Compare and contrast.
To recap - your aftermarket gauge is reading wrong almost certainly.
You are probably running 10+psi. R34 doesn't like too much extra boost - get Nistune.
Thanks for the help again guys.
So it seems my boost controller setup is working fine and I have bypassed the 2 stage solenoid OK. The issue is just with my boost gauge setup.
Can anyone tell me from the picture I supplied in my first post, that where I have tapped the vacuum lines for the aftermarket gauge in is correct, and if the broken hose from the valve nearby would cause the incorrect reading on the said gauge? I'm going to have a crack and solving this tonight.
Also out of interest, when not on boost the aftermarket gauge reads quite low, towards -20 and I'm thinking that should be more like -10?
Edited by Everlong-S13
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
