Items:
1. 1993 R32 RB20DET OEM Motor (Short)
2. 1993 R32 RB20DET OEM 5 Speed Manual G/Box & Clutch
Item Condition:
1. Motor has standard internals and is in VERY GOOD condition. Regular servicing (5000 kM oil/filter change, yearly water change etc.). Has been relatively standard all its life until 2007 where it made 170 RWkW on the standard turbo. All that is required is a quick clean. Hydraulic lifters RARELY click on start up (if you leave the car for a week or two and start the car they will tick for about 1 second until the head sees oil pressure/flow).
Comes as a short motor i.e. intake/exhaust manifolds and related parts (associated piping/tubes), ancillaries (a/c, p/s etc.) are NOT INCLUDED. Included is the OEM turbo. If you need further clarification with what comes with this please either contact me or Google what a "short motor" includes.
2. Gearbox is a standard OEM 5 Speed manual from an RB20DET. No noises. No crunches. VERY GOOD condition. Oil changed with Castrol oil (Sydneykid's thread in Drivetrain section of this forum) every 20,000 kM. Comes with a Heavy duty clutch (unknown brand and type etc. until I pull it out in a week or two). Clutch has never slipped. Condition of this part will be know once I have removed them from the car.
Extra Info:
Items will be removed from the car in the coming weeks. More info will be updated as it becomes available as to the condition and type of parts removed.
I will accept deposits.
I MAY separate parts. However, this will depend on several circumstances.
Contact Details:
e-mail: [email protected]
mobile: 0401 317 009
PM me if required
Price and price conditions:
1. $500 ONO Will ship at buyers expense
2. $200 ONO Will ship at buyers expense
OR $600 ONO as a package deal. Will ship at buyers expense.
Edited by R32Abuser
Kyle: I do have a clutch master cylinder and slave cylinder. PM me for details or further information.
$200 for gearbox and clutch BTW. Unless I find out the clutch is something of considerable value.
Slidnreds13: Not for a cheaper price.
I am currently awaiting a deposit on the G/Box.
Motor is still available. Few interested buyers.
Cheers,
David
Items:
Item Condition:
Extra Info:
Contact Details:
PM me if required
Gearbox sold pending deposit/payment
Engine up for sale.
    • I’m also conscious that e85 is slowly being phased out. Not all United’s have them anymore. Can’t take the risk of being low on petrol and assuming the servo will have it.
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
