Havnt posted for ages!
Anyway my clutch isnt working very well. The clutch has been in the car for 10,000km which is when i rebuilt the engine compleatly and it hasnt been well since then. It felt stiff but i expected it to as the rebuild was 9 months. We adjusted the slave cylinder (the adjuster behind the clutch pedal) and fixed the problem (shifting was easy as using one finger) thinking it just needed adjusting. But over time (10,000km) it lost its pressure and every 1000km's it would get harder and harder to shift, so the problem came back over a period of time.
A month ago i pretty much couldnt drive it. Shifting from 2nd-5th it would be almost imposible to shift up and down (very soild) and sometimes grind and 1st i would have to use the weight of my body to shove it in and when it did go in it would make the whole car thud. It also clunks and makes the car shudder if i take off only while rolling and releasing the pedal, stand still it takes off like a normal clutch, though if its on a hill i have to rev to about 4000RPM so i can take off. For a temporary fix i have spun the adjuster to max and the problem is back only a month down this time and im starting to not be able to select gears already.
i dont know what it is and im not losing and clutch fluid and there are no noises but the shifter gets very loose feels like the bushes are worn but when i tighten the slave cylinder the shifter wont jiggle anymore.
It was a Exedy heavy duty kit and the box is the GTS-4's version of the FS5R30A (all thats really different is the transfer case). Clutch was a OEM grade exedy before rebuild and although sliped didnt do this.................
Any help?
https://www.sau.com.au/forums/topic/362774-clutch-lost-its-throw/
is the pedal very low too?
yes, it grabs about 3cm from the floor and not very much play. If its on a hill ill have to rev is to 4000RPM and take it out all the way to get going.
It's almost certainly the clutch master cylinder shagged and internally bypassing. New master cylinder, fluid and bleed (followed by a couple of weeks of tweaking the clutch pedal adjustment - bloody Nissan!) and it will be sweet.
sweet, i was thinking master or slave as the pressure is going down over a period of time and the clutch doesn't clunk and drag when it i tighten the master up. Also didn't mention my friction point is half way on the pedal when i tighten it so ill take a punt for the master cylinder first. Working for Nissan parts means its only $110 new :D
Hi I have had the same problem, And the 2 cylinders were near new, I was doing other work and the car sat for 4 weeks, I finish the work jumped in the car started and to my foot on the clutch and there was nothing there, a bit down the bottom. So i jumped under the car with a flat bar and push the Slave cylinder piston slowly back upto the cylinder as fare as i could and it bought the clutch peddle back up to about 3/4 peddle, I gave it a couple of slow pumps and it was good as new.. Im not 100% sure but over time the fluid siphons into the slave cyl creating a vacuum and holding the master cyl piston at the bottom of the cylinder , Hope this fix helps, Jamind
    • There aren't boost creep issues, it's not engineered around the restriction of the cats but if you haven't tuned the engine a full decat + exhaust can flow enough air to run off the end of the OEM load scales and you will get a pretty substantial reduction in ignition timing as a result. I recommend using DFCO, avoiding ignition cut limiters, and avoiding popcorn tunes along with running a cat unless you enjoy a perpetually soot-covered and potentially burnt bumper.
    • Small update, it's been slow moving over the Christmas period with money having to go everywhere thats not my car 😅. I got myself a little present to myself from "santa" in the form of some tidy radiator mounts from fitmint automotive to get rid of the stock ones that look like they have been in an accident before and then straightened by a caveman. I know I should've replaced the rubber bush at the same time but I had no idea how bad they were until I was replacing the mounts. Decided to order their dash mat while I was at it as I feel like I am lucky enough to have a pretty decent condition dash and I don't want to risk it being ruined while it's parked in the aussie sun while I'm at work. I have found another electrical fault to add to the evergrowing list to eventually chase down. Every time I replace my taillight globe it blows within a day of use, I'm starting to think my life would be easier if I took a few minutes to learn how to use  a multimeter 😂.   Had some luck with finding a series 2 drivers headlight on marketplace to replace my mismatched series 1 headlight, a subtle difference but it's nice to have a matching set of lights now.   I returned to the air con problem due to being sick of this summer heat, found a good condition condenser to replace my leaking one! I got it in the car and was happy when I got the thumbs up that the system was now holding gas. Sadly the compressor is not kicking in for some reason, we even tried branching the relay in the fuse box. I have tried to do some research on the issue with no clear understanding of what the fix is, so for now it will be placed on the backburner until I can be bothered to look into the wiring to the compressor. The last small mods I have done was cutting the horizontal vents out of the front bar, not really in a functional airflow sense but I just think it looks better as I am not a fan of the series 2 bar. I also switched the shift knob out for a hosoboyo aluminium grex style one, it has a really nice more direct driving feel than the outdated rubbery oem one. Thirdly, I chucked on one of the ebay bonnet strut kits. The fitment is decent and they seem to work fairly well. They have only given out once while the car was parked facing downhill, I think if I was working under the bonnet I would still put the oem hood stay up to be precautionary as to avoid getting a speedy concussion.
    • Got pneumonia, haven’t played with her in a while, but I’m back now. Previous owners cut bonnet pins into the bonnet. My choice try find a replacement or spend $15 get some pins myself to cover up. Now only one small hole to cover. looks shit now, but when the bonnet is red again. Be good 🤞
    • No R32 GTSt had 15" wheels. 205/55-16 was standard GTSt fare. 4.36:1 is standard R32 turbo auto diff. I think the manual was too, not 4.11. 4.11 and 4.08 were R33 namual and auto respectively.
