hahaha unlucky Shell.
nice work zebra, we'll make a horse of you yet
if your battery only lasted a year maybe check to see you got the right CCA rating on the battery for your car, unless you have a smaller battery fitted to clear FMIC piping.
  • Replies 91
Would have been a year and a half, counting back, and the NRMA fitted it.
Thanks so much for offering to come over too, looks like you can do more exciting things on your Friday arvo now :D
Nrma batteries - if it fits in the hole and the terminals are on the right side......its the right battery..........:glare:
yeh no problems at all. damn it now i HAVE to fix the carbies on my VW on friday arvo hahaha
And you don't live in Kambah! lol
Soooooo anyway... car started tonight with teh jumper pack :blush: Doesn't explain the grindy noise but obviously the battery's farked so will replace that and see how we go.
And now I will lock this thread so no one can reply and call me a tool for having a 3 page thread about a stupid flat battery :rolleyes:
Well weak battery maybe meant it didn't have enough power to act against the spring when pushing the gear out to meet the flywheel, yet DID have enough to spin the motor without any load on it.
Yeah could hear the pin engaging but not doing anything else.....then tried again and made the good old rattle gun sound of a flattery, then started on the 3rd go.
(this is all with my jump pack hooked up)
So once it got a bit of juice she fired up :)
Where do you recommend, the Battery Factory or somewhere?
I have Pat's battery pack so I can actually drive it someone instead of having to call them again.
Hahaha all very embarrassing Shell.
Glad to hear it started and it's running now :D
hehe it's ok I'm used to it :D
as Verms said try Lee and Thomas auto electrics aka battery world in phillip. they are auto elecs so if you ask for a battery and mention you not sure the size of the old one is right they should be able to help you out :thumbsup:
im pretty sure they sell GS YUASA branded batteries that have a 3 yr warranty but cos abit more
Went there today... was going to get one of these but they had over-ordered stock of some Optimas that were $200 and so they gave it to me at the same price that the GS YUASA was ($165).
Sooo happy to have my car back working again!!!
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
