hahaha unlucky Shell.
nice work zebra, we'll make a horse of you yet
if your battery only lasted a year maybe check to see you got the right CCA rating on the battery for your car, unless you have a smaller battery fitted to clear FMIC piping.
  • Replies 91
Would have been a year and a half, counting back, and the NRMA fitted it.
Thanks so much for offering to come over too, looks like you can do more exciting things on your Friday arvo now :D
Nrma batteries - if it fits in the hole and the terminals are on the right side......its the right battery..........:glare:
yeh no problems at all. damn it now i HAVE to fix the carbies on my VW on friday arvo hahaha
And you don't live in Kambah! lol
Soooooo anyway... car started tonight with teh jumper pack :blush: Doesn't explain the grindy noise but obviously the battery's farked so will replace that and see how we go.
And now I will lock this thread so no one can reply and call me a tool for having a 3 page thread about a stupid flat battery :rolleyes:
Well weak battery maybe meant it didn't have enough power to act against the spring when pushing the gear out to meet the flywheel, yet DID have enough to spin the motor without any load on it.
Yeah could hear the pin engaging but not doing anything else.....then tried again and made the good old rattle gun sound of a flattery, then started on the 3rd go.
(this is all with my jump pack hooked up)
So once it got a bit of juice she fired up :)
Where do you recommend, the Battery Factory or somewhere?
I have Pat's battery pack so I can actually drive it someone instead of having to call them again.
Hahaha all very embarrassing Shell.
Glad to hear it started and it's running now :D
hehe it's ok I'm used to it :D
as Verms said try Lee and Thomas auto electrics aka battery world in phillip. they are auto elecs so if you ask for a battery and mention you not sure the size of the old one is right they should be able to help you out :thumbsup:
im pretty sure they sell GS YUASA branded batteries that have a 3 yr warranty but cos abit more
Went there today... was going to get one of these but they had over-ordered stock of some Optimas that were $200 and so they gave it to me at the same price that the GS YUASA was ($165).
Sooo happy to have my car back working again!!!
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
    • This seems like a pointless exercise. There is no E30 availability. Ongoing availability of E85 should not be assumed. Flex-fuel is the only sensible approach, so you can use E85 when and where you can get it, 98 when that's al you can get, and anything in between as you fill it up and drain it down. And if that means replacing the pumps, fitting a flex capable sensor/ECU/whatever has to be done to these Renault shitboxen, then.....so be it?
    • Sorry, I wasn't very clear.....just that the standard injectors are apparently good over 600rwhp/450rwkw which you won't get to on standard turbos anyway.....they are much better sized from factory than we are used to in RBs.
    • I'm not sure where you are, but United Terrey Hills has E85.
