hey guys just thought i would pass on a little info to help out people deciding on buying second hand pop out dvd players/car audio units instead of new.
i bought it second hand off a forum member for what i thought was a bargin 300ish dollars. lasted a good year-year and half with no dramas.
i recently have been experiencing problems with it, the screen would not function sometimes coming out when the button pressed other times not moving or only coming out half way then pausing. I eventually took it to a car audio place to find out the mechanism was gone and neded to be replaced. payed the $80 standard fee to have it sent away and looked at thinking it might cost me 100 or so dollars to fix it. got the call from the guys to find out just to replace parts in the screen and nothing else was going to cost $850 obviously this was >_<>_<>_< (due to the parts not being easily available anymore.)
when you factor in a brand new one with more applications cost less.
even the guy at the car audio place said to me it was pretty outrageous. so while buying a second hand dvd player/unit is great for the cheaper price just be weary of the replacement cost if the pop out screen mechanism fails which is going to be an arm and a leg
yt
And you generally get a year warranty with a new one....so lasting a year and half second hand plus the previous usage isnt that bad at all, even if you got new it would be out of warranty.
Also if your buying something that has a lot more mechanical moving parts like a pop out screen you would expect more issues as time goes on and hand in hand is the cost to fix it.
Its bad luck you have to get a new one, but there really wasnt much point to this thread.
Bought one New about 2 weeks ago off a 31 forum member, wired it all up.. and no display on the screen, tried wiring the H.brake ground to the chassis, batt, and H.brake.. still nothing.
also it didnt accept CDs for a few mins. bit annoying as i have been trying to contact him and getting no reply.. tho he is on just about everyday. im not saying its his fault, but im sure if i buy something new it should work.
depends on where you go and what you get in terms of warranty. i am not saying that i didnt get my money's worth, i believe i did but getting it fixed is a whole different story, if this advice was here for me to read at least i would have had the knowledge to choose. if it helps one person make a better decision than in my opinion it is worth it
mosr radios arent worth fixing, unless its a easy fix, the cost of radios has fallen so much and so many new features its not worth fixing old junk, imo
    • Nope. The seal is in the drive. A new cable would just fill up and continue to convey oil to the speedo head. To check if this is what is happening, take the cluster out, dismantle the speedo and have a look. You probably don't even have to dismantle it. If there is oil coming up the cable, the drive into the speedo will be grossly greasy. I had to manually (and delicately) clean the gunk out of my speedo.
    • Thanks for the quick response mate, and I agree Nismo 555s, Z32 and high flow 2871 in OP6 housing (run by PowerFC) would all be "period correct" and should be a simple, reliable and reasonably quick track car.
    • It is normal for a speedo to read 0-10% high (unfortunately), intended by manufacturers and ADRs (although not in this case) to ensure your speedo does not read low if your tyres are worn. Speaking of which, what size tyres do you have on the rear, and what does they tyre placard say you should have? you can use this https://tiresize.com/calculator/ to determine what % difference that is causing Personally, when I buy tyres for a car I buy a size that will bring the speedo back to being more accurate; it if it reads 5% high I buy tyres that are 5% larger diameter. If you had an electronic speed sender like R33 onwards, the other option is to add a speedo adjuster but that won't work in R32. Finally, you  might be able to find a different sized gear for the speedo sender but that will be limited to what already exists (and I don't know what sizes do)
    • OK...so dumb question to check....do the hi beams actually come on when the push the stalk to engage them (keeping in mind your headlight switch must be at ON as well)
    • Nah it factory manual not sure about ratio but it looks like there’s been some work at the rear
