hey guys just thought i would pass on a little info to help out people deciding on buying second hand pop out dvd players/car audio units instead of new.
i bought it second hand off a forum member for what i thought was a bargin 300ish dollars. lasted a good year-year and half with no dramas.
i recently have been experiencing problems with it, the screen would not function sometimes coming out when the button pressed other times not moving or only coming out half way then pausing. I eventually took it to a car audio place to find out the mechanism was gone and neded to be replaced. payed the $80 standard fee to have it sent away and looked at thinking it might cost me 100 or so dollars to fix it. got the call from the guys to find out just to replace parts in the screen and nothing else was going to cost $850 obviously this was >_<>_<>_< (due to the parts not being easily available anymore.)
when you factor in a brand new one with more applications cost less.
even the guy at the car audio place said to me it was pretty outrageous. so while buying a second hand dvd player/unit is great for the cheaper price just be weary of the replacement cost if the pop out screen mechanism fails which is going to be an arm and a leg
yt
And you generally get a year warranty with a new one....so lasting a year and half second hand plus the previous usage isnt that bad at all, even if you got new it would be out of warranty.
Also if your buying something that has a lot more mechanical moving parts like a pop out screen you would expect more issues as time goes on and hand in hand is the cost to fix it.
Its bad luck you have to get a new one, but there really wasnt much point to this thread.
Bought one New about 2 weeks ago off a 31 forum member, wired it all up.. and no display on the screen, tried wiring the H.brake ground to the chassis, batt, and H.brake.. still nothing.
also it didnt accept CDs for a few mins. bit annoying as i have been trying to contact him and getting no reply.. tho he is on just about everyday. im not saying its his fault, but im sure if i buy something new it should work.
depends on where you go and what you get in terms of warranty. i am not saying that i didnt get my money's worth, i believe i did but getting it fixed is a whole different story, if this advice was here for me to read at least i would have had the knowledge to choose. if it helps one person make a better decision than in my opinion it is worth it
mosr radios arent worth fixing, unless its a easy fix, the cost of radios has fallen so much and so many new features its not worth fixing old junk, imo
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
