Turbo/Manifold etc...
Garrett T04Z on ETM high mount manifold with ETM dump & front pipe including plumbed in Trust wastegate. Turbo, manifold & dump are all ceramic silver coated.
This is ALL brand new un-used, with exception of the gate, which is in good condition. Custom-made for 30 conversion into GTS-T. Will fit any 30 conversion, but will not fit 26 in a GTR due to clearance issues with front drive shaft.
Biggest bargian on SAU!! $3500 + postage
post-35087-0-37433700-1304313233_thumb.jpg post-35087-0-39157500-1304313243_thumb.jpg
Injectors
Brand New Siemen 700cc top feed injectors - never been used, fitted to the rail only (rail NOT included)
$500 + postage
Surge Tank & Fuel Pumps
2L Surge tank + 957 Bosch in-tank pump + Bosch 044 external pump
Perfect working condition - $350!!
Wheels
Volk AV3 - suit GTS-T - 9 inch rear, 8 inch front +37 & +35 offset.
2 piece rim with some gutter rash and minor marks - no cracks or buckles - tyres are worthless
$450
Prefer pickup but MAY be able to arrange freight at buyers expense
post-35087-0-14823400-1304313787_thumb.jpg post-35087-0-00569300-1304313794_thumb.jpg
Twin Blitz Blow off Valves
Twin Blitz blow off valves on 33 GTR pipe in perfect working condition
$150 + postage
GTR twin pipe
GTR twin pipe with twin turbo emblem
$50 + postage
Also have another with no emblem - $30
CAS
RB CAS - suitable all RB engines except 34 - in good working condition
$100 + postage
post-35087-0-67351800-1304314027_thumb.jpg post-35087-0-89798000-1304314037_thumb.jpg
Brakes
Rear brake calipers for 33 GTS-T - pads are worn, calipers in good working condition
$100 + postage
All goods as described or money refunded
Contact Noel 0413 863 207 or PM
https://www.sau.com.au/forums/topic/362817-high-performance-parts/
No chance of separating the BOVs Noel? I'm in the market for a single basic ATMO BOV but don't want to spend some stupid amount of money on a fancy anodised thing that sounds like a dying cat.
Sorry Troy. wont seperate them mate.
noel - hey mate
I'll buy the brakes, are the seals in tact (including the dust cover)?
Lizzeh, Howyadoin babe.
I will have a looksee at them tomorrow and dutifully report back.
thank you!!! xoxoxo
even if they need new seals... ill take them!
my rear brakes seized (i think i told you this story)... turns out i was right all along! lol
Sif a woman be right Lizzeh. :nyaanyaa: seals are fine, calipers need a bit of a clean up but thats womens work.
When are you back in town? Or do you need them sooner.
I need them super fast. If you just drop them off at a pack n send, they will pack and ....wait for it....send them. Its a bit more expensive, but I don't mind!
Pm me bank dets
    • Back in January, I noticed my car felt noticeably weak. I had the injectors cleaned, which seemed to solve the problem -- until now. Recently, the car suddenly lost power again while driving. Suspecting the injectors, I brought it to the mechanic. He recommended replacing them entirely, saying the current ones were getting unreliable and fiddly to work with. I could not find a direct replacement for my current injectors. The closest match I found were 440cc injectors. This led me to look into the possibility of upgrading -- and of course, that would mean remapping the ECU. From my research I found: The OEM Part numbers are 16600-72L20 and 16600-72L21 Both the RB20DE and RB20DET use the same 270cc injectors. There are much better options out there over the old OEM injectors. Nistune could be a viable tuning option. While the RB20DE isn’t explicitly listed on their site, the ECU is essentially the same as the GTS-T version - just with a different map. The ECU code on mine is listed as supported. One concern is finding a tuner who works with Nistune. Aftermarket ECU like Haltech and Link, but this would be the most expensive choice (and possibly overkill for a mostly stock RB20DE) I admit that I am very new to the tuning scene and would appreciate any insight or recommendations regarding this.   These are some SAU links where I got some of my information from for reference: https://www.sau.com.au/forums/topic/380324-rb20de-injectors/ https://www.sau.com.au/forums/topic/477396-factory-270cc-injectors/
    • The inspectors are not forensic by any means but if you forge your documents and/or badgings on vehicle parts and are found out, the consequences are just far bigger than if you just run illegal parts. And their job quite literally is to cross reference what parts you got installed and what your papers say you got. Something as silly as your suspension being 1mm too low will fail you. Nonetheless I asked if someone knew the damn pipe and I certainly did not ask for smartassery or underhanded comments, no idea why you need to be told this. Great way to waste both our time.
    • As useful as you explaining what forgery is... But then again, I wasn't aware your inspectors were also forensic experts and inspect nameplates on each component to confirm everything is original. They must inspect roughly 3 cars a year at that rate. You're right though, my comment doesn't help you in anyway, so I'll go talk to my wall now. Cheers.
    • Say that to the guy that is going to fail your inspection or tow your car for illegal exhaust modifications. If you have anything else useful to say, please go tell your wall.
    • You must be fun at parties.
