  T0nyGTSt said:
Oamps (ie. Jim Richard's team sponsor) have an office in North Parramatta.
They are a Zurich dealer.
$350 no questions.
T.
I got quoted $577 - so much for $350..... im the same age as you TonyGTSt, how come i got quote $227 more than you. Oh and another thing they didnt even ask what car i drive!! They only wanted year of car, my age and my postcode.
Help me out!
CTP insurance provides compensation for other people injured in an accident when you or the person driving your vehicle is the driver at fault.
Australia wide, 24 hours a day, your CTP insurance covers:
your passengers
other road users, such as drivers, passengers, pedestrians, cyclists, motor cyclists and pillion passengers
injuries caused through the use of a trailer
It does not cover:
you for personal injury if you are the driver at fault in an accident
damage to property or other vehicles
CTP Insurance is compulsory, and must be taken out when registering a motor vehicle.
From the above, it will not go on your car, but rather driver experience (re: AGE), as well as the density of people and structures within your most common driving area, thus providing the chance (re: risk) of 3rd party accident (re: POSTCODE)
i think a lot of people are lucky that it doesnt go on vehicle, driving history, etc....(then again - some are unlucky)
  red900ss said:
No they're not.
What do you think CTP means? :confused:
Compulsory Third Party Green Slip (CTP) and Third Party Property Damage are two different things.
CTP - http://www.aami.com.au/products/ctp/fctp_nsw.htm
Third Party - http://www.aami.com.au/products/car/fthirdparty.htm
Here's the comical explanation frequently used in my industry...
You see both Third Party Compulsory (CTP) “Greens Slip” and Third Party Property Damage “Also a green slip” are printed on green paper. That’s the colour you get when you mix blue and yellow together in equal quantities. In the insurance industry we use these terms to help costumers decipher between what they are liable for and what they are entitled to if an accident may occur. Most people think that if they have paid their (CTP) they will be covered for the damages of the vehicle or phone box they side swipe, where in fact they are only covered for the injuries of a third party involved.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
